Question about Maytag LAT3600A Top Load Washer
Machine comes on fills with water but will not advance on its own. But it seems the cycle continues because it will go off after a while but when I lift the lid the water still there and if i manually turn the unit will continue where it left off at.
  • Maytag Master
  • 3,740 Answers
This symptom of the unit filing and then not washing can be caused by few things.
1. The water level pressure switch not making contact to the motor control circuit but shutting off the water valve. There should be 120 VAC on the yellow wire of the water level control pressure switch when the fill level has reached the correct level.
2. An internal timer contact problem for the motor control circuit. Power for the timer motor should also be present on terminal 14 of the timer.
3. A defective motor speed switch. There should also be power on the yellow wire going to the motor.
All of the above power is sourced via the lid switch.
Black wire is power in. You know you have power in... as it fills.
Schematic:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1330708&pkw_=basket&model_id=5170285&NewWindow=1
This is going to take a meter to isolate the problem. Changing parts can get expensive but treouble shooting with a meter will result in determining where the failure has occurred.
Thanks for using FixYa.
Kelly
Posted on May 30, 2010
  • Kelly
    Kelly Aug 31, 2010
    There is always the possibility that the timer motor is getting weak causing the timer to hang. Damaged internal timer contacts can cause mechanical hang ups also. From reading that you can turn the dial and it will continue from that point.... the water level float switch and the timer have to be part if the troubleshooting process. One of the two will be causing the problem. Usually when a float level pressure switch fails it won't agitate but will spin. The cycle will hang where it is supposed to agitate. If it is ;a timer caused mechanical hang problem it could be any where on the dial... but usually repeats in the same general area of the timer dial.
    Kelly
  • mary ervin
    mary ervin Dec 13, 2013
    My will fill with water then nothing?
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washing machine gets stuck on cycles
Apr 01, 2009 | Frigidaire Washing Machines
Machine fills with water & then clicks but goes no further. It will drain but no other function seems to work
That is probably a problem with the timer.
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Oct 11, 2008 | Bosch Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Maytag LAT3600A Top Load Washer Logo
    294 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
