Question about Whirlpool Duet GHW9150P Front Load Washer
Control locked light on? Unplugged for a couple of days hoping maybe something had to reset. Still will not operate.
    President:
  • 949 Answers
Did you try holding the 'end of cycle signal' button for 4 seconds?
Posted on May 30, 2010
Freezer runs for approx. four days with operation normal. Then the temp. panel of front door displays a symbol that looks like a short L followed by a period. Then the temp. gauge and the interior light...
From what I read, the "L." that you see on the control panel indicated that the controls have been locked. According to the manual if you hold down the "alarm reset" button for 3 seconds the "L." will disappear allowing you to control the temperature again. I don't as of yet know what is causing your overall problem though...
Nov 04, 2013 | GE FUF14SVRWW Upright Freezer
I own a 2006 saturn vue. My check engine light stay on and my anti-lock brake and traction control light come on about every couple of days then it goes out. I had it check with a scanner i think the code...
Have you driven thru any big snow piles/drifts/berms or deep mud etc? It sounds like your ABS sensor is/was damaged.
Get the EXACT code and reply.
Cheers,
Td
Dec 21, 2017 | 2006 Saturn Vue
The control locked light is lit and the washer won't start. I unplugged it and the light continues. what should I do now?
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Nov 15, 2009 | Kenmore Elite HE4 Electric Dryer
My washer is locked. I unplugged and plugged bach
holding the end of cycle button is the control lock,not the door lock. Check to be sure that the control lock light is off--if not, hold end of cycle button again till control lock light goes off.
I've given up on the door lock after a few years fighting it, and researching. There is a solution on fix-it that may work--if it is computer(mother board I think they call it)--and not door lock mechanism. I've read many posts from duet owners that replaced door lock mechanism just to have it be a soldering problem with the "mother-board" that makes the machine "think" there is a door lock failure.
Here is link to a fix-it post I used today to get my machine open and retrive clothes it has held hostage for several days:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brake sensor? something else?
You have a faulty wheel speed sensor. This is a magnetic pick up sensor on your wheel bearing hub and it controls your abs. If the car can not sense all 4 wheels then the abs will default back to normal brakes and your traction control will not work. Look at your wheel bearing hubs and check for these sensors. They are on the underside of the car and are black plastic with a wire comming out of it. A piece of gravel may have broken the pick up or the wires to a sensor may be broken as well. To replace it is usually a couple of screws on the hub assembly and a plug to disconnect from your wire harness.
May 27, 2009 | 2003 Mazda Mazda6
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Nov 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Small rca truflat tv won't turn on
the problem is that the tv was probably set to pwr on only with remote control.........i have the same problem and lost the remote...........BUMMER! Trying to figure out how to reset the programming without the remote.
hope that helps someone!~
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Control panel locked light is on
ck for a button with hold to lock under it hold button 3-5 sec
Jul 02, 2008 | Whirlpool GEW9250 Electric Dryer
Not cooling
- Check if there power is a supply by opening the door of fridge, if there is a light then there is a supply. But no light check the circuit breaker. Or try another outlet for testing. If your fridge is digital control and there is some error display, then reset the error.
- Check the thermostat setting if set to high cool, and check the compressor at the back of the unit if running, if not there is something wrong to your control or compressor itself, if the compressor is operating and no cool at all maybe your unit is out of refrigerant, please call a qualified technician.
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
Whirlpool Duet GHW9150P Front Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal De
