Question about OKI C9800hdn Led Printer
Error 357 I have okidata c9800 the error is 357 waste toner. I have replaced the waste toner, but still get the error. I have checked to see if any of the gear is broken, but it is not that I can see. Anyone know what the problem can be.
Hi - take the waste toner unit out and restart the printer. You'll now have a different error 'Check Waste Toner'. Open the front cover and put the waste toner back in. Let the printer go through the usual checks and hopefully all should be well.
In my experience this can be caused by not shutting the printer down fully before changing the waste toner.
JohnnySheffield
Posted on Aug 04, 2011
Replaced my waste cartridge with a new one and still getting error 357 waste cartridge full
See if your printer has some sort of reset button. contact Oki for tip.
Maybe you have to reload the software in printer. Try also unplugging printer while turned on. Then press and hold the power button for a minute or so. then plug back in and press power button.
Feb 15, 2016 | OKI C9600hdn Laser Printer
OKI C9800 CYAN TONER SENSOR ERROR
Exactly what is the error on the operator panel?
Jul 30, 2014 | Oki Electric Industry C9800 Printer
C9800 fatal error 145
Toner Feed Switch Error. Toner Lock Lever Open Error
145 = Magenta Imaging Drum
Mar 11, 2013 | Xante Ilumina Digital Color Press Printer
Indication is INK TONER WASTE BOX FULL Not sure what to do, if any thing? Al
You need to replace the waste toner collection bottle. The waste toner bottle has to be replaced every 30,000 Letter pages on average. Order part number 42869401. The directions will come with the replacement unit. Remove and dispose of the old waste toner carefully.
Manuals for the C9600 series printers are available from OkiData: http://my.okidata.com/PP-C9600hdn.nsf?opendatabase . You can order the waste toner bottle for $14 from OKI here: http://esales.okidata.com/IWCatProductPage.process?Merchant_Id=1&Section_Id=5001&pcount=1&Product_Id=1102864 . Other online vendors have the part as well.
I hope this helps.
Jun 30, 2011 | OKI C9600hdn Laser Printer
9-357 problem
Hi there! The Black Toner Dispenserof your machine is broken. Please check the following
1. The Toner Dispenser Motor located at the back of the Toner Cartridge Housing Assy (Behind Black Toner, larger Motor at the top)
2. Black Toner Dispensing Auger set located just below the Toner Cartridge.
3. The Dispensing Assembly behind the Developer Waste Container.
Regards
Apr 27, 2011 | Xerox DocuColor 12 Color Copier
What is error 357 waste tuner box is full okidata c9800
The printer always puts out a little more of each color toner than is actually needed in printing. The excess gets dumped into the waste toner bottle.
The replacement part number for this printer is 42869401 and should last 30,000 pages. Order one from an OKI service center and it will come with the replacement directions.
I hope this helps.
Apr 18, 2010 | Office Equipment & Supplies
Fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Aug 28, 2009 | OKI C9600hdn Laser Printer
Error 357 waste toner full
If you dumped out the full waste toner bottle The gear that drives the gear on the waste toner bottle has broken off.
Dec 18, 2008 | OKI C9600hdn Laser Printer
OKI 9800 with "342" error code
problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Aug 24, 2007 | OKI 9800hdn Laser Printer
OKI C9800hdn Led Printer Logo
414 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
