Scan jet 5370c: main logic board has burned resistor "R105". what is the description, part no. or value of this resistor? thanks
  • 78 Answers
You'll find exactly what you're looking for by visiting the following page:
http://forums12.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1207667889226+28353475&threadId=131258
Best of luck.
Posted on Apr 08, 2008
  • Darren Perlmutter
    Darren Perlmutter Apr 08, 2008
    Or to be even more precise, here's a quote:
    "The value of the resistor is 30 ohms (orange, black, black, golden (or silver)."
  • 3,037 Answers
I hope that helps you, but I suggest you that use a more powerful resistor, because it can blow again
Here is what one guy did
and Quote
[The Solution (for me):
Resistor R105 replaced by 30E (some Watts).
Removed C118 (was creating Shortcut for 12 Vdc) resistance after 7812(Q11) was only approx. 10E.
After this Scanner was working but after a scan there was always a white page.
Checked voltage after 7805(Q9), was only approx 2.5 Vdc. Replaced 7805 with a new one.
Now 5 Vdc is present again and Scanner runs again and is scanning as never before....]
  • Benjamin Patri
    Benjamin Patri Apr 08, 2008
    let me know if you have any further questions or find that you need some more help
    Good luck and have a good day
Hisense LCD32V77
it must be a power supply malfunction; if you`re not a tehnician , please contact the nearest repair shop.
Nov 18, 2013 | Vizio L32 32 in. LCD HDTV
Power problems
Do you have the schematic for this TV?
Oct 29, 2008 | JVC AV-20420 20" TV
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
Hello i have incubator brand suro 20 com king its running but there is no heating a parts burn inside the main controler i like to ask if you can supplied me with the schematic diagram to find the suitable...
I have a king surro with a temperature control fault 2 resistors next to power transistor on pcb burnt out I can tell values of any other components on pcb but does anyone have a controller board who can tell me what value resistors are steve-- protodezine@gmail.com
Jan 06, 2011 | Heating & Cooling
R 105 is 30 Ohms
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1303903552885+28353475&threadId=131258
Oct 20, 2009 | HP ScanJet 5370C Flatbed Scanner
Burned resistor R105 on circuit board HP 5300 scanner
Hello there:
if you contact radio shack you can get all of the technical information about the resistor from them, as far as fixing it i would contact the manufacture of the unit to see what options are avaiable ok.
best reards mike
Aug 10, 2009 | HP ScanJet 5300C Flatbed Scanner
HP Scan Jet 5370C
The R105 Resistor in the Australian version of the Scanjet 5370C, if that makes any significant difference, is orange black black gold. I don't have my handy translator so I don't know the impedance. I have no idea of the wattage, however it is about the same size as the R92.
I was hoping that may be my problem, but no such luck.
Good luck with changing the resistor.
Feb 18, 2008 | Office Equipment & Supplies
HP ScanJet 5370C
Replace the R 105 with a 30E one.
I read somewhere to remove the C118, it can work without
Dec 15, 2007 | HP ScanJet 5370C Flatbed Scanner
44 people viewed this question
k24674
jasbo
jasbo
