Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
How to reverse air flow for summer - Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
    Guru:
  • 351 Answers
There should be a small switch on the side of the fan body for reversing the direction. If this is remote control only then that is where to look for this feature ,,
Please Vote !
Posted on May 30, 2010
Is Conia air conditioner CA24001 split system reverse cycle I cannot get heat?
Sounds like either bad reversing valve or to get you going during the summer someone may have wired it to stay energized all the time which would have been a thermostat problem.
May 30, 2016 | Dometic Heating & Cooling
Does a kichler ceiling fan remote model # uc7206t have reverse?
www.kichler.com/customer-service.aspx
Almost all ceiling fans have reverse. The switch is usually on the side of the fan so one must get a ladder to get to it. Air flow to be up in winter and down in summer.
Nov 14, 2014 | Dryers
The difference between the heat pump and condenser
Well...they are kinda the same. The condenser is where the refrigerant is condensed from a gas to a liquid. When in AC mode this happens outside at the AC unit. (You ever put your hand over a running AC unit in the summer? Feels warm!). When in Heat Pump mode the process is reversed. Instead of condensing the gas to liquid outside (which creates heat) the condensing happens inside and helps warm the building up (with the help of the fan of course). So essential the condenser is where the gas is condensed into a liquid, which creates heat. A heat pump can reverse the direction of the flow and cause this condensing to happen either outside or inside.
This is a very watered down version of what happens but I hope this is sufficient for what you are asking.
Jun 29, 2014 | Goodman Heating & Cooling
After modifying our 20x 48 Summer Escapes pool to utilize our Intex Saltwater system - why is the saltwater pump showing low flow?
Index salt chlorinators need a certain flow rate. Check the flow rate on your pump to see if it is strong enough.
Mar 27, 2017 | Intex Pool & Spa
Should the blades of a reversible ceiling fan turn clockwise or counterclockwise in the Summer?
Seeing as to how hot air rises and cold air falls, you may get better results with air circulation if you have them blowing upwards (as it will help pull the cooler air up and flow elsewhere.)
Jun 21, 2012 | Hampton Bay 24002 Ceiling Fan
Fan has a switch for winter and summer. Is it up or down for summer?
This is probably a reversing switch changing the rotation direction. Check the air flow from the fan to find if it is pulling air up or pushing it down. Pushing down from the ceiling will be the 'winter' setting, pulling up, the summer. Since warm air gathers at the ceiling, it is beneficial to have it move that air downward during cold weather and have it pull up cooler air from the floor in summer. I frankly don't notice much difference though.
May 30, 2011 | Hampton Bay 24002 Ceiling Fan
I know I should reverse the direction of the ceiling fan for summer/winter. Which way is which?
you want the fan to turn anti clock ways in winter as this sucks the cold air upwards pushing the hot air from the roof downwards. and clock wise in summer blowing cool air downwards to cool you
take care
please remember to rate this repair.
Aug 03, 2010 | Craftmade International Craftmade...
Have a goodman 3 ton heat pump - ac worked excellent this summer - however when in the heat pump mode we hear sounds like gravel or rocks inside the big copper line - heat works but what causes the sounds/
You are reversing the flow of refrigerant in the heating cycle. Since liquid is now flowing through the suction
line it has less volume than the gas from the cooling
cycle that was flowing through it.. Making sure the outdoor unit is soundproof might eliminate this.
Feb 14, 2010 | Heating & Cooling
Car may not restart appears it ran but computer shut it down
its the mass air flow sensor world i firugered it out i got 97 deville 120000 ran great all summer till it got below 40 hard to start when cold like it was the fuel pump but it wasnt it was the mass air flow sensor
Jan 10, 2010 | 1997 Cadillac DeVille
Water doesn't stop
hi thanks for the question the problem seems to be a water valve especially a summer home sediment from well water gets stuck in the water valve or just a weak spring in the water valve i would replace the valve thanks the appliance doc
Aug 03, 2008 | Jenn-Air JCD2389G Side by Side...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
130 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
