You question is not that specific so i can't give you the specific answer, there're several ways to configure this settings, but it depends on the Operating system you are using. If you are using windows Xp, log off from the desktop and press Ctrl+Alt+Del simultaneously on the login screen (sometimes you'll need to press several times), a small logon window will pop up, type administrator on the username box and if a password was set with the administrator, key in the password, or if there's none, just press enter after typing the "administrator". After you are logged in with the administrator account, go to control panel - user account - create new - and create an account (any username that you want to give) with the administrator privilege (rights) {you should select Computer Administrator}. Again log off and login using the new username and password (if you've set a password). Now with that account, you can do anything with your computer. If it's not Xp then the problem is difficult being without the administrator's rights. If you have another account with administrator's rights, then you can disable the Guest account. Good luck Thanks for using FixYa.
You may be logged on your computer using a guest account. A guest account can access the computer but has limited rights and permissions (e.g. downloading applications, computer configuration changes, install software or hardware, etc). Please ask your technician or access the Administrator account to successfully install the printer driver. You may also ask the owner of the Administrator account to grant you additional rights and any permission to your guest account so you can make future changes.
