Question about Samsung Refrigerators
I have a samsung RS2555SL the fan does come on and the refrigator side is not cooling the freezer side is cooling.
  • neildezone May 30, 2010
    this answer is too vauge I am a novice
    President:
  • 1,561 Answers
Fan not running will cause the fresh food and the freezer sections not to work properly. If the condenser fan (the one under refrigerator) is not working, the compressor will cut off on the overload.
If the evaporator fan is not running, there will be no airflow to the freezer or the refrigerator.
The solution to this is to check to see if something is blocking the fan to prevent it from running.
If there is nothing blocking it then replace it.
Replacing this unit will solve the problem and both unit will function well after the replacement.
Take care.
Posted on May 30, 2010
  • 1 more comment
    The fan is not running and there is iceing on the pipes to the tank does your suggestion still apply
  • Sulaimon Jimoh Olayemi May 30, 2010
    I said if the fan on your refrigerator is not running, you check to see if there is nothing blocking the fan from running.
    If after checking, and there is nothing blocking the fan from running, then it means the fan is faulty and will need to be replaced.
    You will need to replace the fan on your refrigerator in other to make the work fine.
    Take care.
    that solution does not hold for the problem with you refrigerator, i did not see your comment. the problem with your refrigerator is defrost problem.
    Defrost problems can cause the fresh food section not to work. You
    need to find out why it’s not defrosting. There are three things that
    cause a defrost problem: defrost heater, defrost thermostat and defrost
    control.
    If you have an older refrigerator, it probably has a
    mechanical defrost control. Find it and turn it clockwise until the
    refrigerator cuts off. (Note that the defrost control is normally
    located either in the refrigerator near the cold control or at bottom
    behind the kick plate). If your refrigerator is newer it will have an
    electronic defrost control and you won’t be able to turn to defrost so
    just continue without doing so. Now that it’s in defrost, wait a few
    minutes. If the defrost heater gets hot, replace defrost control. If it
    doesn’t get hot, then the problem is either the heater or the
    thermostat.
    At this point, you need to melt the ice. The best way
    to melt the ice is to use either a hair dryer or by using hot water
    (this will be faster but will make a mess).
    Once the ice is gone,
    you can check the heater by unplugging wires and using an ohmmeter
    to check for continuity. If you have continuity, the heater is good and
    you should replace thermostat.
    Take care
  • 857 Answers
It sounds like you have a iced up evap in the Fresh Food side so You need to clean all the ice near the top light and all from all the places.
Appart from this you should also get the thermistor checked and the frig fan. Doing this will fix the problem.
  • 1 more comment
  • Jayant Jha May 30, 2010
    Let me explain you a bit more :
    Just clean all the ice near by the ice box and near by the top light from all the places. If this doesnot resolves your problem you might need to replace the thermistor.
    what is a thermistor and where might it be located
    If you don't know much about it in that case i think you should take help from an expert because these things are not easily replaced.
    Just clean all the ice and see if it works for you.
    Good luck...
2 Suggested Answers
  • 821 Answers
SOURCE: samsung RS2555SL NITHER FANS ARE
hello,it's the fan that brings air into the fridge that has frozen condensation on the refrigerator fan blade.the refrigerator uses a different fan each,so if you definitely check the refrigerator you will probably find ice build up round the fan blade. melt off with hot water,and you will have the refrigerator working as normal back.
wish you good luck,
take care.
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Samsung Refrig Compressor Problem
Can you tell where the hum is coming from?
Jul 10, 2013 | Refrigerators
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Samsung RS2555SL NITHER FANS ARE COMEING ON REFRIGEATOR IS NOT COOLING FREEZER IS.
wish you good luck,
take care.
May 30, 2010 | Refrigerators
The digital display on my rs2555sl Samsung stopped working and the fridge and freezer are not cooling. The fridge is only 4 years old. what could the problem be?
circuit board controling temp to both fridge and freezer is out. Could have been fried by an electrical surge or just a badcircuit board.
Sorry
Dave
Jan 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Samsung double door refrigerator/freezer is not holding the tempature in the refrigerator. When you attempt to reset the temperature and press "power cool" nothing... temp remains around 56 The freezer...
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Jun 15, 2009 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
257 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
