Question about Nuova Simonelli Oscar Coffee Maker, Espresso Machine
Water comes out of the steam wand
About half of a coffee cup of water , and then it gets too stea, .then gasps and water comes out again.. Then the maching keeps taking in water . I am kind of handy so i am woundering if there is any parts i can replace
  • 421 Answers
Sounds like you need to descale the brew head.
Posted on May 30, 2010
Water will not come out
Helpful Hints ' Home Espresso Repair
www.espressorepair.com/helpful-hints/
Why isn't water coming through my espresso machine? ... clean, waffle side up, smooth side down, and that the water hose is not crimped. ... After one cup of waterhas flown through the brew head and the steam wand, the vapor lock will be fixed. ...When the ready light comes on again, turn the steam knob open to release ...
No water out of the brew head - Starbucks Barista - iFixit
Dec 28, 2015 | Coffee Makers & Espresso Machines
Delonghi Magnifica 3300 doesn't make coffee, only wet grounds and water in the grounds container, everything else seems normal
Hi JB, not sure if you've junked your 3300 machine by now or had the problem fixed already. Nevertheless, allow me to share with owners of DeLonghi Magnifica Espresso machines who encounter similar problem to yours. Incidentally, mine is a Delonghi Magnifica 3200 which is very much the same as the 3300. Firstly, try to ascertain if the pump is working normally. When the machine is ready to brew coffee, turn ON the steam/hot water knob and see if it pumps normally and for more than 30secs at least. My machine could pump for short durations between 5secs to 20secs max before the water light came on. I checked the flow meter connection but is all seemed well. I noticed signs of water leak (dried up chalky water stains) where the steam wand exits the control panel. Upon opening up the control panel, I noticed a larger patch of dried up water stains on the wand valve assembly. Bought a set of steam wand assembly replacement and to replace the leaking one. It's been some six month now and I'm enjoying my daily cuppa again. Btw, my Delonghi Magnifica 3200 has been serving me well for 10 years! Apart from the steam wand replacement and a faulty micro-switch, I only had to carry out the usual descaling and replacing worn out O-rings.
Feb 10, 2013 | DeLonghi Magnifica 3300 Espresso Machine
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Our machine will not make coffee or water will not come out of the hot water dispenser.
water and steam wand work
but i cannot get any response when i press the cup buttons
Feb 08, 2011 | Lavazza Espresso Point Capsule Machine
Our machine when turned on and menu is pressed it will show energy saving press again ventilate shows. no action
Hi
When the ventilate message is showing, push the water button is you have one then open the knob on the right with a cup under the steam wand. You should get ewater from the wand. If you don't get water from the wand check for a plug in the steam tip. If you don't have a plug in the steam tip, you may have a plugged flow meter.
Dec 18, 2009 | Gaggia Titanium Espresso Machine
Please help
The Magic Comfort Plus machine has a selection for the temp through the menu for the three sizes of coffees buttons. Using the menu button, scroll through until you come to temp section, then select the coffee size button and and change the temp, example-- Select maximum. Press the menu button to set it.
If that does not help, when a machine gets full of calcium (needs descaling) that also will lower the temp. You might have to descale it three-four times.
And remember, when you descale, run the solution through the steam/hot water wand and also the espresso/coffee dispensing nozzle. Only doing it through the steam wand (like the manual says) will only do 1/2 of the machines water sections!!! I usually run 1 cup of solution through the steam wand and 3-4 cups through the espresso dispenser.
Dec 23, 2008 | Saeco Magic Comfort Plus Espresso Machine
Ventilate problem
Can you make a cup of water or there will only comes a half cup?
If you only get a half cup then you have to replace the flow meter in the machine.
Apr 27, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
Open Questions:
Nuova Simonelli Oscar Coffee Maker, Espresso Machine Logo
163 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
