Question about Car Audio & Video
My neighbor gave me a jensen xa 120 amplifier for my truck and a subwoofer but i dont know how to hook it up to the crossover
  • 185 Answers
I will tell u now that nobody will tell any body how to hook anything up to the car not with out paying just pay the ten dollers to talk with a teck. and then ask sum one
Posted on Apr 09, 2008
SOURCE:
Their are 2 power wires,2 negative wires and 2 rem wires...how is this wired..im getting ready to get this put i
Some amps come with extra, power,rem,ground, so you can , power up another Amp Without runing to many wires. , or using a power block.like a parallel, being your 1st Amp your power block, and your remote, ground .
Apr 03, 2016 | Jensen JXA8BA2 Amplified Subwoofer, Max...
I have a Jensen KS212 and I'm connecting it to a home theatre receiver direct to see if it works but nothing comes out of it. Does this mean the sub is not working or there's not enough power from...
Hi, welcome to FixYa..
Your subwoofer requires a seperate amplifier that has low pass filter in the pre out system, which means it will allow all low frequency signals from the input section of the amplifier/ crossover. Your receiver has combined signals of high, mid and midbass signals that will not be able to drive your subwoofer. That is the main reason why some receivers has "Subwoofer Out" to allow you to use "Active Subwoofer systems" (also known has self powered or has a built in amplifier w/ subwoofer)
For you to use your Subwoofer, it must have a seperate amplifier, connect it to Sub out of your receiver and from there you can hear the difference. Hope this helps.
Jul 13, 2011 | Jensen KS-212 Car Subwoofer
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
Will the jensen a4000 run subwoofers
Its ought to. Thats what it was really marketed toward with the 2 channels bridged somehow and then put to individual subs in tandem. However, there is no built in crossover. This is a twenty year old amplifier and popular demand had not made it such that built in active crossovers came standard. In that sense its not a great choice for subs. My brother got one and it sounded like a## because he never bothered to add a crossover. Class a/b amps are sooper cheap right now. If moneys no object get a "2000w" amp for about 80 bucks on amazon or whatnot.
Jan 16, 2011 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Jensen XA 2100 Amp. Need High Level input plug diagram. In other words need to know what each of the 6 pins connects to.
the black wire is ground, white is + and white/black is - that's for the left side speakers and the gray is + and gray/black is - that's for the right side speakers and that hooks up to the speaker wires coming from radio to high level input plug if you need a diagram this is the website http://a248.e.akamai.net/pix.crutchfield.com/manuals/110/110xa2100.pdf and look on page 5 it will show you. please vote and leave high marks. Thank you and I hope i answered your question
Jul 30, 2010 | Jensen XA2125 Car Audio Amplifier
Over heating
If it is overheating then it is being driven too hard. You need to either reduce the volume, decrease your crossover frequency or allow the amplifier more air; i.e.; if the amplifier is covered with something like a blanket then it needs to be removed.
Jul 15, 2010 | KLH ASW10-120 Subwoofer
4 chanel amp I dont know how to conected,to radioand one subwoofer
Hello canelo63,
Your question appears under the product listing for the Dual XPA4100 but the in the text you say the amp is actually a Jensen, so it's not possible to provide specific connection information.
But most bridgeable amps can be connected to a single subwoofer and the other two channels used to drive a set of regular speakers. I'd connect the front speakers to channels 1 and 2 and wire the subwoofer to the bridge connections of channels 3 and 4. On the XPA4100, the bridge terminals are the first (negative) terminal on channel 4 and the last (positive) terminal on channel 3.
Hope this helps.
Jun 01, 2009 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Low pass crossover
Low-pass crossover
Both sets of inputs sum the left and right channels together and the
resulting signal is passed through an adjustable low-pass crossover before
being amplified. The crossover control allows you to adjust the upper limit
of the subwoofer's frequency response from 40 to 120 Hz. The subwoofer's
response will begin rolling off above the frequency you set this control to.
You should set the crossover frequency to obtain a smooth and seamless
transition from the subwoofer to the main speakers in your system. If your
main speakers are smaller units with limited low frequency output, you
may wish to choose a higher frequency (such as 100-120Hz) than you
would with larger speakers which have greater low frequency output. With
larger speakers, you might start with this control set lower, such as 80Hz.
Jan 05, 2009 | Velodyne CHT-10 Subwoofer
Need Help
input and output slots???? is it playing although thump present,low current could be the problem check for good connections as well as adequate wire guage.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
