Question about JVC DR-MV100B DVD Recorder/VCR
Tray won't open.
I've tried everything I can think of--short of brute force.
  • 484 Answers
the reason the tray wont open is because there is a problem on the mechanism that controls the opening and closing of the tray.
most likely the rubber that assists in opening and closing the disc tray.
to fix this, unscrew the player, turn it on and press the open button, it'll respond and stop.
you'll see a kind of mechanism that carries the tray, its engine is by the side of the tray.
when the tray stops responding after you've pressed the open button, try to carefully sit the engine properly and press the open button again and it will respond.
if you cannot do that on your own,try to take it to a service center for further repairs.
take care
Posted on May 30, 2010
HOW TO FIX A 2006 BRUTE FORCE NO POWER WHEN TURN ON KEY
Check fuse link under the seat. Look for the main 30 amp fuse. Also, could have shorted wire in the key housing where the key goes into the ignition. Put ohm meter on and check for continuity. this will tell if there is a short in the wiring. Hope this narrows it down for you.
Aug 31, 2014 | kawasaki 2006 Brute Force 650 4x4
Kawasaki brute force 750 cranks over then locks up it won't turn over by pulling the rope
sound to me you got faulty security switch check them 1st, specially the kick stand, most bike locks up if you try to place it in gears while the kick stand is still on. hope it helps
Dec 24, 2012 | Motorcycles
Samsung Optical Drive SE-208 tray rattling won't eject
if you look on the drawer you will see a little hole.push a pin in the hole and the drawer will open.
Nov 15, 2012 | Samsung Optical Drive SE-208AB/TSBS...
I have a sheet stuck under the agitator of my GE gtwn3000mws. I've tried to use leverage to brute force the agitator out and it was a no go. Then I took off the top cup looking for the bolt to r
Remove the fabric softener cup, remove the plastic insert, then there is a 7/16th bolt you need to remove and the agitator will lift out.
Here is a diagram of the tub assembly.
Regards,
Richard Roth
http://appliancecafe.com
Nov 13, 2012 | GE GTWN3000MWS Washer
Iv been given a bugaboo cameleon from interstate and it won't open ? and the seat is also attached now ..and I can't get it off .'it was made in 2005. Thank you .
Frame won't open with seat attached and the seat should not fit on a closed frame? The seat is the locking component for the frame. Someone has used brute force to get it like that and it'll take brute force to undo the damage. Get a can of silicon spray and lubricate the seat locks and turn stroller upside down to get some to run down inside the seat legs. Press both square seat release buttons inward (one side has a small safety lock you heed to side across before you push inward) and heave up! You cant do any more damage than what may have been done. Click here to see the correct way to set up your stroller.www.fixya.com/support/r9134331-assemble_frog_or_cameleon
Jul 26, 2011 | Bugaboo 'Cameleon' Stroller
DVD will not eject. How do I get dvd out ???
laptop or desktop?
easy way, try to right click the drive and click eject from inside windows.
brute force way:
on a desktop get a paperclip and shove it in the tiny hole. including a firm shove to pop the tray loose, then grab the tray and gently tug the drive open. keeping a sharp eye on any hanging or obstructing objects.
laptop, look for the hole and follow the same directions. or take the cd bay out of the computer, most companies put an emergancy open method, check the users manual.
Jun 10, 2010 | Apple PowerBook G4 Mac Notebook
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Jam
mine did that, brute force is the solution. when you hit the button to open the cd tray grab the silver plate and pull until it comes open. to close it, just hit the button and push it back in.
Mar 27, 2008 | Microsoft Xbox 360 Console
JVC DR-MV100B DVD Recorder/VCR Logo
601 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
