Question about NetGear WGR614 Wireless Router
I can't find my wep key info., and I need it to install Tivo. How do I find my wep key? I have netgear. Please don't tell me to type http://192.168.1.1. Once there I still need my wep key information to move along.
  • 739 Answers
OK Connect your computer to the router with an ethernet cable.
Type 192.168.1.1 in the browser and then return.
Then type in the router's gatekeeper codes. Unless they have been changed they are admin and password.
Then when you have passed the gatekeeper, look down the left hand side for the wireless setting tab. Click on it.
When the page opens scroll down to the security section AND THERE IS YOUR WEP KEY. Generally it's the first of the four. Normally it will have the bullet marking it.
Your WEP key is only used by the wireless side, It is not used to access the settings of the router.
Posted on May 30, 2010
Wn2000rpt refurbished installation
I found this answer online - but I didn't save where - I did add to it a bit after the ** Leah DH(:
Netgear WN2000RPT Setup Instructions
Maybe since I purchased a refurbished Netgear WN2000RPT it didn't come up with setup instructions but once I emailed support they quickly responded with the info below and it worked immediately.
Do this setup and your Netgear WN2000RPT range extender will work:
1. With the help of a paper clip, press the reset button on the back of the extender for 20 seconds (please refer to the label on the bottom of the extender for reset button location). Release the reset button after 20 seconds and turn off the extender. Turn the extender on after few seconds.
2. Connect the extender to the computer with an Ethernet cable. Make sure that there is no connection between your router and the computer either wired or wireless. (I did this part by turning off the antenna to my laptop)**I went to the Network and Sharing Center and on the left click on "Change Adapter Settings" after that right click on your Wireless Network Connection and choose "Disable". Don't forget to re-enable when you're done.
3. Open a browser to start the Smart Wizard. **I had to use Internet Explorer and compatibility mode
4. Please select your Preferred Language and click on continue.
5. Let the Extender detect the list of networks available in the locality.
6. Select your network and note down the security assigned for your network and click on continue
7. Type in the security key for your network,please note that if you have WPA security assigned on your network type the network key in passphrase box and if you have WEP security setup on your network type in the network key in the Key1 box and click on continue. **I've read elsewhere NOT to use WEP security with this extender.
(Read this one carefully)
8. Assign a name for the Extender as per your choice, also make sure that option "Use the Same security and passphrase as those for the existing network" is checked and then click on continue. **Under the step #3 Configure Extender I had to right click and refresh because there was no "continue" button!
9. Let the smart wizard establish the connection. On the next screen Click on the button "I have connected to the extender network" and click on continue.
10. Now click on the finish button to close the page.
11. It should ask you to save the page as bookmark, please save the page for future use.
12. Now open a new browser and check if you are online. (turn your antenna back on)**Re-enable your Wireless Network Connection.
13. You can now unplug the Ethernet cable from the extender and scan for the SSID of the extender and connect to it using the same network key as for you existing router.
The most important part of the Netgear WN2000RPT setup is that you should NOT just plug it in and use the setup wizard. The setup does not make it clear what you should do when you get to the page with Key 1, Key 2, Key 3 & Key 4. If you follow the directions above which I got by emailing to ask about Netgear WN2000RPT setup then it will work the first time without any problem at all. Just read the Netgear WN2000RPT setup instructions above carefully first and then go through the step by step setup instructions slowly, one at a time and be sure you do exactly what it says. If you follow the directions above you will find that you can do your Netgear WN2000RPT setup without any problem at all.
Need More Help?
Need more help? Don't call me! I only know that this worked for me and it was super easy to follow the directions. I don't work for Netgear and I'm not really a techie.
I own a Florida ad agency.
Feb 11, 2012 | NetGear WN2000RPT Repeater
Where is the WEP/WPA code on a Netgear router
The WEP / WPA security information can be obtained by accessing your Netgear router setup page. You'll need the router's IP address to access the setup page. From your computer, go to Start > Run > type "cmd" (w/o the quotes), hit Enter > DOS black screen appears, type "ipconfig" (w/o the quotes), hit Enter. Take note of the Default Gateway IP address - that is your router's IP address.
Pull up a browser and enter the IP address in the address bar, hit Enter. You will then be asked for your router's Username and Password, enter the required information. If you don't know the info, please contact your router manufacturer for assistance. Once you're in the router setup page, go to the wireless security settings to check the WEP or WPA code.
Should you still need further assistance on this matter, please contact your router manufacturer.
I hope this helps.
Feb 04, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Cannot find wep key on net gear dg834g v4
to find the wep key of a netgear router, you first need to ensure that you are connected to the netgear router. after ensuring that you are connected, open a browser, internet explorer or firefox, type 192.168.1.1 or www.routerlogin.net it would now ask you for a username and password. username is " admin " password is the word " password " itself. you would see the netgear page next. click on " wireless settings " on the leftside of the screen. there you would see your WEP key on security options
Sep 11, 2011 | NetGear WGR614 Wireless Router
What is the security key of netgear wireless connection?
Security key in side the router. To get the key you need to access the routers web interface. Please follow the steps below on a wired pc. A pc which is directly connected with the netgear router using an Ethernet cable.
1. Open internet explorer and in the address box type http://192.168.0.1 and press enter. It should ask you a user name and password. User name is admin and password is the word password. click on login or ok.
If you don’t get user name and password window with http://192.168.0.1 and try http://192.168.1.1 or http://routerlogin.net
2. Click on wireless settings on the left hand side.
3. Under the security section if the security is wep then note down the key one and this is the security key you need.
If the security is something else then you wont be able to see the security key it will ******. In this i'll suggest you to change the security key to wep, encryption should be 64 bit and authentication type should be open. In the security key one box you need to type in the security key, The lenght of the key should be 10, you can only use a-f and 0-9. For example 123abc567f. and save the settings.
Try connecting on the wireless pc.
Note: if you change the security key then you need to connect all the wireless devices with the new key.
Hope this helps you!
Rashish.
Aug 16, 2010 | NetGear WGR614 Wireless Router
How can i find my wep key
your Wep Key is set up in your router, you have a netgear your netgears IP address default gateway is 192.168.2.1. Username: admin Password: password this should get you into your router look for security this will give you information to what your wep key is.
Jun 18, 2010 | NetGear DG834G Router
I want to set up my new PS3, but cannot get a WEP key What to do?
You need to plug the router into a computer and login in to it. some info should be written on the router. open a explorer session and in the address bar type in 192.168.1.1 and a menu should come up to type in User, Password. you may need to set up the router from accessing the different menus you should be able to see your wep key if it's already set up.
Oct 24, 2009 | NetGear WGR614 Wireless Router
How to install
look u need three things to connect wirelessly
1. Internet from Provider
2. Laptop with Wireless Card or Desktop
3. Wireless Router
pls check all 3 thingds in place connect an ethernet cable provided by netgear to ur internet provider modem if u have one and see u connect at INTERNET port of router at back
also see where u conenct at modem back there might be only one port so u dont have difficulty in it
then switch On ur Laptop Wireless from the button provided a light will blink with Dish Antenna Type icon or Tower icon then ur laptop will automatically detect the wireless router with name of default or Netgear or something like that
and it will auto connect to router
if u want to setup WEP security so no one else can use ur internet service u can setup WEP KEY for access u can ask me after u get connected
pls rate me WELL !
Jul 08, 2009 | NetGear DG834G Wireless Router
I cannot find the network security key to enable - WEP info
Please check out this Netgear page on how to set up WEP. It's much faster than if I had to explain it all.
May 31, 2009 | NetGear DG834G Router
I have forgotten network key for my NETGEAR DG834G router can you help me please.
on your router install cd there was an option to set WEP access. If you can get to this just disable WEP key security feature or type in the address bar the routers url- 000.000.000.0 this will get you to the routers setup utility.
anonymoose
Oct 11, 2008 | Computers & Internet
Cannot get wireless connection through router
Hi MistiShay,
You did mention that it was working fine for several weeks suddenly your wireless computers stopped functioning and your getting a message that the security key in incorrect. This only means that its either your entering the wrong encryption key or someone changed the previous security key to something else. By the way what type of wireless security did you configured on the router initially was it WEP or WPA, if its WEP(64 or 128 bit) and your using a bulit-in wireless adapter on your laptop you need the default WEP key because the passphrase only works with a Netgear WLAN Utility.
Know if your having difficulties accessing the setup page of the router you may need to check on your browser settings, turn off the pop up blocker and firewall temporarily, also try another computer. Now if all fails you may need to press that reset button on your router and set it up again.
I
Jul 28, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear WGR614 Wireless Router Logo
334 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
