Question about HP Compaq nc6230 Notebook
Will not boot up all the time - HP Compaq nc6230 Notebook
  • HP Master
  • 11,800 Answers
The hard disk is dying. Make a full backup of all your data, replace the disk and reinstall.
Posted on May 30, 2010
My toshiba satellite a50, i want to change boot order to usb drive
If you want to change the boot just for one time press and hold F12 during the booting proces but if you want the computer to boot every time in USB mode you must press F2 to enter the bios setup, look for the boot priority option chnage save, exit and restar.
Enjoy
May 15, 2014 | Toshiba Sattelite A105-S2071 Notebook
Tip
Speed up Windows Boot Time
Many people ask about Windows boot times and how to make your boot time shorter. This is a quick tip about how to eliminate some of the unneeded or unnecessary items from your Windows XP/Vista/7 boot time.
First, make sure that you are logged in with Administrator privileges.
Next, Click the Start Button (Windows logo button in Vista and 7) and then click Run. (In Vista and 7 you can just type into the search box under the Start button). Type "msconfig" (without the quote marks) and then click OK or press enter.
In the System Configuration Utility, click the Startup Tab and deselect all of the items. In the Services tab, check the box for Hide all Microsoft Services and then disable all the other items.
Now, you will need to reboot your computer after applying those changes and time the boot up. If the time is dramatically faster, then it is likely that one or more of the items in the Startup Utility are causing the lag in boot time.
Go back into MSCONFIG and go to the services tab. Re-Check a few items, apply the settings and reboot. MAKE SURE TO WRITE DOWN WHICH ITEMS YOU'VE RE-CHECKED. Now time the boot up process again. Continue this process of re-booting, timing, going into msconfig and checking a few items back, and rebooting and timing until you find the items that add significant time to your boot up process.
Once you've found those items that are adding time to your boot time, you will need to determine if the item is one you can leave unchecked - or if it is something that you may need to run during startup. If it is a critical program, you can try to get it to boot quicker by reinstalling the program or seeing if an update to the program will fix the issue.
Hope this information is useful!
on Nov 20, 2011 | Microsoft Computers & Internet
Tip
Speed up boot time
to speed up boot time on a vista pc click start>type MSCONFIG>press enter>go to boot tab> check the no gui boot checkbox this will get rid of the loading bar at startup and replace it with the aurora background this makes boot up about 6 seconds faster but you will not know if your pc has frozen
on Dec 06, 2009 | Computers & Internet
Belta notebook usb/network booting windows system?
When you press the power button normally the boot options will display on the screen. Most times it is the F12 key to select the boot option. This is a temporary change only good for the current boot cycle.
Also most times the F2 key will get you into the Bios or System Setup where you can change the boot option and make it a permanent change.
Apr 29, 2012 | Computers & Internet
"Long Boot Time With VISTA"
Try disabling some start up programs. These can slow down your overall boot time.
Oct 08, 2011 | Microsoft Windows Vista Home Premium...
Hi , i've HP ML370 G4 server , after power failure , the server can't boot . i try to reinstall memory & remove all parts & fix it agian but the problem still there , then after about 1 hours it's...
It may be that the lithium battery is dead; usually a CR2032 button battery. Signs of CMOS Battery Failure Dom Tech Computer Blog
Go into the BIOS settings during initial power on boot up, often F10 or F2 are common. Check the date and time, if they are off, you should be able to temporarily boot by setting the date and time but you'll have to do it every time you boot. If the date and time is off, and you set the correct date and time and it still doesn't boot, you'll want to make sure it's booting to the correct drive.
When it doesn't boot, does it give you any error?
Jul 04, 2017 | HP ProLiant ML370 G4 Server
Dell optiplex gx 240 cannot boot from CD rom every times it says strike f1 to reboot or f2 for system set up
at the same time goto set up screen by pressing f2 and then change the boot sequence as cd drive to be first boot device and then try to boot from cd and as soon as you restrt and after dell logo it giuves you a message press any key to boot from cd at the same time press space bar be very quick as you have only 2 seconds to press the key or it wont boot if that does not work then the problem is with the cd drive.
Oct 27, 2009 | Computers & Internet
Boots ok then after a bit freezes up with following
1/ some time bootable virous and wowm can not give to boot regularly . once time iface same problem i took out harddrive and formated another computer then it worked. 2/ some time old drive cannot boot so we change to new for only bottable purpose.3/ some time we face this problem by bootable cd ,change other to check.4/ some ram can work but not boot so we change while we are going to boot.4/ if cpu fan is damage you should get any kind of message as thermal heat . computer is shuting down thanks (nepal)
Jul 12, 2009 | Dell Inspiron 6400 Notebook
F8 does not work
well I actually not so sure about the malfunctioning of "F8" button..because i always boot my PC after i restart my PC ..i press F2 ..for boot from CD ..try booting..without logging into safemode..ok
May 25, 2009 | Microsoft Windows XP Home Edition
How booting time can be reduced?
Just check the BIOS settings whether everything is correct in that , Clean your RAM and refix it, Delete the Temp files used to load the PC
Aug 28, 2007 | Microsoft Windows XP Professional With...
HP Compaq nc6230 Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
