Monitor display is fuzzy and pixelated - Computers & Internet
    President:
  • 1,099 Answers
Hi.
Focus voltage on the CRT is usually in the range of 2-8 kV DC and should be controllable over a fairly wide range by the focus pot - usually located on the flyback or a little panel in its vicinity:
If adjusting the pot results in a position of acceptable focus, you may be done. It is not unusual for the focus setting to drift a over time.
If the setting is already as good as possible but not really good enough, the CRT may be tired. Alternatively, the filament voltage may be too low. Check for bad connections in the filament circuit.
If the optimal setting is out of range of the focus pot, the problem is likely leakage in the focus divider in the flyback or one of the components on the CRT neck board.
Also see the sections: "Focus adjustment" and "Focus drifts with warmup".
The focus wire usually comes from the flyback or if the general area or from a terminal on a voltage multiplier module in some cases. It is usually a wire by itself going to the little board on the neck of the CRT.
If a sparkgap (a little 2 terminal device with a 1/8" gap in the middle) is arcing with power on, then the resistive divider has shorted inside the flyback, focus board, or HV multiplier - whatever you TV has - and the this unit will need to be replaced. Ditto if the SCREEN control affects focus and/or vice-versa.
Using a suitable high voltage meter (range at least 10 kVDC, 1000 M ohm or greater input impedance), you should be able to measure it connected and disconnected. The ground return will be the outside coating of the CRT which may or may not be the same as the metal chassis parts. If the voltage is very low (less than 2 kV) or too high and the pot has little effect:
When measured right off of the source disconnected from the CRT neck board, then the problem is probably in the focus network in the flyback (or wherever it originates). Sometimes these can be disassembled and cleaned or repaired but usually requires replacement of the entire flyback or voltage multiplier. Note: you may need to add a HV (10 kV) capacitor between the focus wire and DAG ground to provide filtering so you get a DC level for your meter.
When measured with the focus wire attached to the CRT neck board with the CRT connected but reasonable with the CRT unplugged, there is probably a short between the focus and another electrode inside the CRT. See the section: Rescuing a shorted CRT.
When measured with the focus wire attached to the CRT neck board with the CRT unplugged, there is likely a component on the CRT neck board that is leaky or breaking down. Also, check for decayed (tan or brown) glue which may turn leaky with age.
Good Luck...
Posted on May 30, 2010
Acer monitor has green lines on the scren
Liquid Crystal Display (LCD) screens use less energy and display a clearer picture than the Cathode Ray Tube (CRT) displays that preceded them. These new LCD screens now dominate the computer monitor market. From time to time, however, pixels can become stuck and a green line can display on the screen. Removing this line is sometimes possible without sending the screen to the manufacturer for expensive repair.
Locate the pixels that are stuck on the screen. Download a free screen repair software program, such as UD Pixel or JScreenFix. Run the software and allow it to find and attempt to repair the stuck pixels. Turn off the LCD monitor. Apply the damp cloth directly over the stuck pixels and use a gentle pressure to spread the liquid within the screen.
Things You'll Need Pixel repair software Damp cloth LCD screen 5 Ways To Fix A Stuck Pixel On Your Screen
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
Feb 22, 2013 | Acer Computers & Internet
I have a new BenQ G2220HD monitor connected to my MacBook as an external display. Since I've had it, it's had problems such as flickering pixels, lines that flicker, screen goes gray and flickers and is...
Your onboard video card is going bad on you computer. Some shops may sale an external video device which can be installed in place of your onboard video and it will fix your problem. Average costs aer about $50. Before you try YET ANOTHEr monitor, please try to hook the computer up to a tv to see if the problem pesists, if so, it is time for the above video adapter
Jan 28, 2011 | BenQ G2220HD Monitor
HP w1907 monitor has fuzzy text
Procedures of acquiring high definition pixel quality
1.power on the computer wait until the desktop of icons display after booting has been completed
2. using the arrow of the mouse or pointer to an area on the desktop without icons, right click to display a prompt list
3. locate the appearance and setting prompt on the list.
4. a click to provide the options to increase the picture quality termed pixels
5. LCD monitors could produce several thousand pixels, select a choice nearly approapiate for reasons explained
a. the highest selection of picture quality provided on the list for a monitor powered by a separate computer with extremely dense graphics like known for modern gaming could cause monitor to blank out as precaution.
b. when selecting a picture quality from the list provided on the appearance settings area after a right click on the desktop, be sure about the compartibility of the monitor and computer unit, explained
c. most modern retail provide system units with higest definition pixel capabilites for several funcitons as gaming graphic and design, connect such a unit to an old monitor would display low quality definition pictures. However, that could be fixed by adjusting the appearance setting only with caution not to select the most highest available from the list of pixels.
Dec 06, 2010 | HP w1907 LCD Monitor
My LCD Monitor "X163w" was purchased in January 10 a black spot is visible at the bottom of the screen. Please advise us the reason & cure, when & where? at email: shrihanuman31@gmail.com
Sounds like a dead pixel(s). Depends on the warranty as to how many dead pixels are allowed before warranty is used etc...most manufacturers have different rules.
Oct 19, 2010 | Acer Computers & Internet
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
Horrible fuzzy display on my external lcd tv monitor - sadness
You need to change the resolution and colour quality under graphics properties on second monito. Put the settings back under the advanced tab, your just pushing new monitor over its limits. You dont need to have the same resolution set as your PC screen. Hope this works for you.
Mar 18, 2010 | ASUS Eee PC 1000HE Netbook
Display suddenly becomes pixelated or fuzzy
just goto mycomputer then right click select properties
display setting adjust the bit of the color make it 32 bit
or if your O.S vista just right click on the desktop click personaliza display setting. change the color into 32bit .
Mar 05, 2010 | Dell Vostro 1310 Notebook
What disavantage about LCD?
The most notable disadvantage to LCD screens is their fixed or native resolution. An LCD screen can only display the number of pixels in its matrix and no more or less. It can display a lower resolution in one of two ways. Using only a fraction of the total pixels on the display or through extrapolation. Extrapolation is a method whereby the monitor blends multiple pixels together to simulate a single smaller pixel. This can often lead to a blurry or fuzzy image particularly with text when running the screen below is native resolution.
Video was problematic with early LCD monitors because of lower response times. This has been overcome by many improvements, but there are some that still have low response times. Purchasers should be aware of this when purchasing a monitor. However, the improvements are often work arounds that can actually lead to another problem of reduced color clarity. Unfortunately, the industry is very poor about properly listing the specifications for monitors to help buyers understand and compare monitors.
  • Blurry images Outside Native Resolution
  • Motion Blur on Fast Moving images
  • Some Models Have Reduced Color Clarity
Conclusions At this point and time, most consumers will likely be purchasing LCD monitors over CRTs. There is almost no difference in the cost to consumers thanks to production improvements in LCDs and the reduction in the production of CRTs. Typically CRTs will only be seen sold with the least expensive of desktop computer systems or by those with special imaging needs such as graphics and medical professionals.
Mar 04, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Pictures on monitor are fuzzy and pixelated. How do I fix this?
Hi shawnpoynter
You may have to change the resolution of your monitor. You may be using a low resolution at the moment.
  • Go to the Desktop, right click,
  • Left click on Personalyse,
  • click on Display settings -
  • choose a higher resolution.
Hope this will solve your problem.
Have a good day.
If this answer work for you, please give a rating.
luciana44
Oct 31, 2009 | E-Machines eView 17f3 17" Flat CRT Monitor
Computers & Internet Logo
612 people viewed this question
David Payne
David Payne
