Have a 29 inch 5 or 6 yr old rca color tv lately we get a colored horizontal bar across the top of the screen and the other day we have fuzzy black lines across the entire screen
    President:
  • 1,099 Answers
CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. (On some sets, this is located on the CRT neck board and may be a jumper plug or other means of selecting service mode - not an actual switch.)
When moved to the 'service' position, it kills vertical deflection and video to the CRT. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection yoke or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection yoke on the CRT.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
Posted on May 30, 2010
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
White horizontal lines on top of screen
Replace all the electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them. Replace the at one time. The fault you see is technically called " vertical retrace lies".
Apr 28, 2012 | RCA 27F524T 27 inch TV
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
May 11, 2010 | Televison & Video
We have a roughly 10 yr old tv that was given to us from friends (therefore we dont have waranty), and it has just started flickering red lines horizontally across the screen. It is a large non-flat rear...
Ur convergence is dead.These problems are colors misalines,3D pictures,colors distorted.U know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Buy a convergence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U $300 for parts and labors.
Feb 16, 2010 | Televison & Video
I'm trying to improve the picture- seems to be TOO DARK- tv is 10 yr old ser3 935351541- ihave tried color adj etc
Rca Screen Control These sets have screen control adjustment usually located behind the speaker grill(pops off -velcro or press tabs) and convergence front board. There are 6 contols on a black molded assembly about 31/2"x21/2" square. adjust only the top controls marked "Screen R G B" the bottom ones are focus
Method:
-turn on set and let warm up for 30 min at least
-switch tv to blank unused video input channel
-adjust each control in turn until you see the picture glow (with the corresponding color) and slightly back off the control - repeat for each color - this will increase screen brightness and ballance your color
Hope this helped.
Oct 18, 2009 | RCA P52945 52" Rear Projection Television
Picture started getting fuzzy then it went out
yes,remove the back of the tv,on the power board you will see the problem.replace those capacitors on the power board.this will allow the set to work.the black bars may still be there.this is an indication of a bad panel.
Aug 08, 2009 | Televison & Video
Pink bar across top of tv screen
This could be from 2 things. 1 is the optical block is going bad or 2 you got a peice of dust blown in from the cooling fan and its blocking the color filter internally. If you are capable you can take the tv apart and blow compressed air into the color block and remove the dust. Hope this helps
May 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
