Question about Microsoft Xbox 360 Console
It says system error E 74 when i turn it on - Microsoft Xbox 360 Console
    President:
  • 1,099 Answers
When you get the dreaded Disk Read Error, it normally occurs for one of two reasons. Either dust has built up on the lens of the laser mechanism, or the operating voltage of the laser has drifted off slightly due to heat and age. Of course, occasionally there are actual failures of components, which cause this, but these are the main two reasons.
Cleaning the laser lens
1) Remove any CDs from the unit and unplug all leads and memory cards. Turn the unit upside down and use the small, flat screwdriver to pop out all the little plastic and rubber screw covers.
2) Take your normal sized Phillips screwdriver and unscrew all the screws.
BE CAREFUL not to damage the eject/power button ribbon cable, as these are very fragile
Take a cotton bud and careful place some of the alcohol on it (but not so much that it is dripping everywhere). This alcohol is the same (or similar) to the small bottle of alcohol which is in audio and video cassette cleaning kits. This is probably the best way to locate a source. Locate the lens (the circular glass part) and very gently rub the cotton bud around the lens in circular motions for about 30 seconds, being very gentle. Once done, flip the cotton bud over and dry the lens with the other end for about 10 seconds.
The laser part slides on rods to reach different rings of the cd. These can become clogged up with dirt and dust, making movement difficult. So, take a clean cotton bud and clean the slide rods thoroughly, making sure you get to all parts and give a good clean.
You have now completed the cleaning process. This often cures read errors and should always be attempted first. Reverse the dismantling process and put the machine back together, making sure you DON’T TRAP the eject / power button ribbon cable, as this can cause serious problems for you if it happens. Power on the unit and try to load both a CD and a DVD game. If all works fine then CONGRATULATIONS on completing the guide successfully. If however there is no change then you should proceed to the next step -
Adjust the Disk Mechanism.
Posted on May 30, 2010
System error. e 74. when i turn on my xbox360
good day sir you can fix it on your own just visit this link for the instruction on how to fix system error 74 on your x box 360 console... if you think that this help you please rate me thank you sir....
http://support.microsoft.com/kb/907536
Jun 16, 2011 | Video Game Consoles & Games
System error E 74
Your xbox is becomeing to hot you must check with xbox to see if you still can send it back to get it fixed.
hope this helps you out
EnVy
Apr 26, 2010 | Microsoft Xbox Console
System error E-74 red flashing light
Microsoft offers warranties on 360's up to 3 years on e-74 error. They changed the policy about a year ago!
Mar 14, 2010 | Microsoft Xbox Console
My xbox 360 says, system error, E 74. Can you help
take your xbox rap it up in 3 or 4 layers and let it over heat itself it is like a really hard reset
Dec 08, 2009 | Microsoft Xbox 360 Arcade
E 74 error message on my xbox 360
thats because that error message means your AV cable has died or the chip inside has cooked, if the error goes away wen you remove the cable its the cable you need to purchase a new one
Oct 26, 2009 | Microsoft Xbox 360 Console
Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
Apr 23, 2008 | Office Equipment & Supplies
E-74 HELP
Just search the same error on the google search and you will be provided with all necessary actions to perform clearly.
Thankyou...!!!
Feb 08, 2008 | Microsoft Xbox 360 Console
1 red light: Error E 74
try the x-clamp fix, also try a different av cable as yours can be damaged
Oct 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
