Question about Ricoh Aficio MP 161SPF Color Copier
WAS SAYING CHANGE TONER, DONE THAT BUT STILL SAYING CHANGE TONER
  • 1,219 Answers
You should vacume and clean the toner bottle holder.
Posted on Jun 02, 2010
I replaced the tone cartridge in my Savin 2400WD copier, but the light still indicates that I need to change the toner cartridge. What do I do?
I hate to say it but switching it off at the wall waiting a minute and then back on sometimes resets its little brain.
I trust the toner cartridge is all correct for this model.
May 13, 2015 | Savin Office Equipment & Supplies
My ricoh mpc 2500 keep saying add black toner whereas there is toner in the toner bottle
If asking for black toner did you change rt toner pump should been one behind the black dev unit. Sometimes when you change it might have to open and close front door. A couple of times make sure you leave it open long enough that it think you change bottle
Feb 19, 2015 | Ricoh Office Equipment & Supplies
I change toner but alarm still on saying toner low
You may have to go into settings to clear the fault of low toner, depending on the year and make of printer. If that doesn't help then make sure that all packaging on the toner was removed and that it is the right cartridge
Oct 10, 2012 | Office Equipment & Supplies
My gestetner DSM735 keeps saying add toner. replaced toner and developer still saying add toner
The first thing i can tell you is that is weird!!!!
Because if you change the developer that error should disappear. It could appear later but not in the moment because the developer already have toner and the TD sensor will read it.
And that's the question: When you said "replace developer" you mean just the developer or the DEVELOPER UNIT??? Is your TD sensor working good????
Feb 23, 2011 | Gestetner DSm735 Black and White Copier
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Machine advising change ink cartridge which has been done but still saying no cartridge
remove the toner cartridge on the side wall inside the printer on the right there are 4 wires that stick out to make contact with the contacts on the side of the toner make sure that these are not bent and stand straight out. remove toner and reseat the toner to the drum unit and reinstall
Oct 04, 2010 | Brother DCP-8040 Copier
Says to empty old toner. we have done that and
The copier is most likely saying to empty out the waste toner. It has been awhile, but I believe it is up front and to the inside right of the front door. It is a milky white container. You may have to open the paper trays to open the door that covers the bottle. I would empty it out very, very carfully and return it back to it's place and that should do it for you. There may be a reset code if the copier has a error code. Good Luck....
Jun 03, 2010 | Toshiba 2060 Copier
We have replaced the toner cartaridge but it is loose and the machine is still saying toner is low
If the old toner bottle is good change the toner into new bottle in the old bottle,and perform toner forced supply.
Sep 24, 2009 | Gestetner DSm635 Copier
Keeps on coming up with install new toner
The toner detection sensor in the toner hopper is either fouled or defective. This is why that no matter what you've done thusfar, it's still saying it needs new toner. Not an easy repair. Recommend a certified Toshiba tech to do the work.
Aug 28, 2009 | Toshiba e-Studio 232 Black and White...
ERROR WITH XEROX C118
Your machine is still working with msg? How many copies already made after displaying this?
Toner sensor may faulty cross check with same module.
Aug 28, 2008 | Xerox CopyCentre C118 Copier
Ricoh Aficio MP 161SPF Color Copier Logo
180 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
