Question about Maytag Microwave Ovens
How big is microwave MMV4184AAB - Maytag Microwave Ovens
  • Maytag Master
  • 9,047 Answers
From page 5 of the owner's manual:
OVEN SPECIFICATIONS
Power Supply 120 VAC,
60 Hz
Input Power 1,500 W
Cooking Power 1,000 W
(IEC 60705
Standard)
Frequency 2,450 MHz
Rated Current 13 A
Outer Dimensions 2915⁄16" x 167⁄16"
(WxHxD) x 155⁄8"
Cavity Volume 1.8 Cu. Ft.
Net Weight 60 lbs.
If you've misplaced yours, you can download it here.
Posted on May 31, 2010
Microwave stopped heating, everything else seem to work. heard a big noise with this started.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ]
May 30, 2011 | Frigidaire FMV156DC Microwave Oven
Microwave does not warm up food after big bang
oh ya man the heating coil is damaged so you have to change it.
Dec 13, 2007 | Whirlpool MH1150XMQ Microwave Oven
The turntable on our Ewave KOT 170SW Microwave oven has quit rotating. Other than that the oven works fine. Any troubleshooting tips? If the turntable needs to be replaced, how big a job is it? I'm not...
i went to replace lite bulbs but didnt unplug it..removed cover and shorted out...now no lite and no turntable but does come on & heats food is it fixable.......ewave microwave kot-131uw....
Feb 28, 2011 | Kenmore 80412 Microwave Oven
Can I use my whirlpool microwave and hood as a regular microwave on top of a tabl?
your asking is its ok to put metal in a microwave? then its a big NO NO!
i know people will say "but i do it all the time!" well its your microwave and its your money,,,and it will cost you to fix it too?
Jun 06, 2010 | Whirlpool WMH1162XVS Microwave Oven
Husband was using it last night (jenn-air jmc700)it's making a rough sound, there is a big brown kinda burn mark that extends from that small little piece on the right side that looks like it encloses...
It's arcing due to the food being attached to the mica plate. It needs to be serviced by an authorized technician. Don't use it or you can break the microwave valve.
Nov 03, 2009 | Jenn-Air JMC7000 Microwave Oven
Maytag microwave Model MMV5100AA turntable no longer turns. Is this an easy fix? The rest of the Microwave works fine. I think I may have flooded the floor of the microwave with water. It worked awhile...
to be realy honest ,,, yes! but be warned there is a very big capacitor inside this microwave and it will be charged up with 1000's of volts,
if you tuch it, your dead! be warned dont tuch it!!!!!!!!!!!!!!
have you ever seen a stun gun working??? they realy hurt you!!!!
well this microwave has the stun gun's very big brother inside of it and it wont stun you,,,it will kill you!
if i were you i would drop it into the repair man to get him to fix it for you,,, or get a new microwave,, there very cheep now,, is it realy worth killing your self for a fuw bucks?
Oct 25, 2009 | Maytag Microwave Ovens
MY MICROWAVE WONT START BUTTONS WORK BUT WONT
the problem with microwaves is there like light bulds,,, fine for years then the just pop off, whatever it is there is very little you yourself can do with it bar check the plug fuse,, if thats ok dont even think of opening it up to have a look inside, you are very likley to just kill yourself
inside that microwave is a big capacitor that holds 1000, of volts and they can and do kill if you tuch the wrong bits of them,
have you ever seen a stun gun work? well that capacitor is its very big brother, only it wont just stun, it will kill you out right...is it worth the risk??? no! so drop it in the shop for repair or better still bump it and get a new one,, and up grade it as well,
Oct 24, 2009 | Whirlpool MH7135XE Microwave Oven
Microwave smells of electrical fire
The magnetron inside the microwave is starting to short out to ground. This happens after use there are small minute cracks on the body of the magnetron and those small cracks are big enough for 15,000 volts and up to 30,000 volts to leak through and arc to ground. It is not a small short but a big one. Replace the magnetron before it burns holes inside your microwave. Replacing the magnetron if you can find it locally or through the internet is pretty straightforward. Unplug the microwave and take the cover off about 6 screws. On the same side as the control panel and right behind it you will find the microwave on top. It is held in place with only three to four big screws. It will have about 4 wires with terminals on them that plug into a couple of places one being the large capacitor that stores all the voltage and discharges it through the magnetron. Take the terminals off and I always recommend with some needle nose pliers with insulated handles. There is nothing to unsolder and to solder. Its like replacing the battery in your car or the electronic module. Take care and good luck.
Jan 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave operates but does not heat
The High Power Transformer (Magnetron) fuse is wrong. Replace it. It will work perfect... The fuse is always hidden in a plastic case fixed at the bottom of the microwave near the big capacitor... My email: neo@intnet.mu
Aug 19, 2007 | Westpoint TV-201 Microwave Oven
Microwave Ovens Logo
217 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
