The screen went all snowy, guess pushed wrong button. and cannot seem to reset remote control again
  • 2,335 Answers
Posting the make and model number of your television will help us help you; the more information we have, the more accurate our solutions can be. If you are using a cable or satellite box, these are good details as well to help us get the bigger picture.
That said, if you have gone from a picture to snow by pushing a button on the remote, you have most likely switched your TV's source from cable to antenna. I used to have a Sony TV that had a button on the remote that could do this, although they are not that common anymore. On that remote, the button responsible for bringing the static on was labeled ANT. If you have one like that, push it.
Come to think of it, if you have an AUX button on your remote, try that. That would switch from the main cable or antenna input to an secondary cable or antenna input, also a good source of static back in the day. (I say 'back in the day' because generally speaking the TV's today have many more 'video inputs' on them, but none of them will generate static when there is no signal; they simply display a black screen. A snowy screen is a strong symptom of an analogue antenna looking for a signal.)
If you have a menu button on your remote, push that. If you can see an on screen menu, then there will be a setup area of the menus where you can choose between Cable and Antenna inputs.
If you cannot see a menu when you push that button, you may have a remote that is capable of controlling different types of devices. Look for a button marked TV on your remote and push that. Now try the menu button again & see if that helps get you an on-screen menu. Try the ANT or AUX buttons again after trying the TV button.
If all else fails, unplug your TV for 10-15 minutes. This will usually cause a set to reset itself. When plugged back in, this action will initiate auto-channel setup again, searching your different inputs to find your antenna or cable signal.
I hope that helps.
Posted on May 30, 2010
How can i change the video input on my rca truflat tv 27F520T without the remote
As there is no Menu button on its front panel. you can't select inputs to this TV without a remote control.
Jun 05, 2012 | RCA TruFlat 27F520T 27" TV
Had power cut when tv was on. Now comes on but black screen and then snowy screen then says not programmed. Can't get remote to work on side control buttons so can't get into menu to try and reset...
It is possible that when the Power supply failed the MEMORY WAS ERASED and so the programs that were memorised on the TV was lost.
Remove the power plug and push down all the controls to drain off residual voltage from the processor to allow it to reset. Now switch the TV after few hours and if there is no result or response from the remote the microporcessor / memory is faulty.
Get help, estimate and concur.
Aug 18, 2011 | Televison & Video
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My daughter pushed a button on the remote. now i can't get a picture. it's snowy. i have no idea what she pushed.
Hello there,
Push the input button on the remote control if you can not find it on the remote Control there should be a input button on the front of the TV .
also make sure everything if turned on
i hope this information was helpful don't forget to rate
Jan 27, 2011 | Samsung LN52A850 52 in. LCD HDTV
The screen has went snowy and wont respond to the remote
Snowy screen, unresponsive to remote control... Sounds like an interference from something. An example... A hairdryer can mess up a CRT really bad. Anything that is likely to create small EMPs will surely mess up your TV and even interfere with the infra-red. Not marking this as a solution, check everything and test the TV. Here's the test: Turn everything off, except for the TV. If it's still doing it then the remote infra-red is just a coincidental failure with the snowy screen. Sorry I can't help you further.
Oct 16, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Snowy screen
press the source button until you reach the correct source
Sep 02, 2008 | Samsung LNT3242H Television
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
