Question about Soyo TFT 19" LCD Monitor
I have 22" model DYLM22R6 KCE. Turn monitor on and Blue light blinks at 1/2 second intervals continuously. Image also appears on screen for the same period of time. Can see normal colors. All seems clear and crisp. Can't read well as the image is apparent for too short a time. Have replugged all the internal plugs and tightened the ground screws. No change. What section should I look in for the problem? Power Supply?
  • John May 31, 2010
    I have the monitor apart. Have examined the PS visually. All caps appear normal. All three PS filter caps may have a slight bulge in the top. Very subtle. Would the symptom I have described likely be caused by bad PS filter caps? I don't want to unsolder and replace them unless it is likely they are causing my proble. Would a faulty backlight cause these symptoms?
  • John May 31, 2010
    I would like to hear from BUDMRTN as he seems to give good technical answers to monitor problems. First two solutions here were were not technical and were too broad and too general or not pertinent to my problem.
    I need to know why the backlight on my monitor is pulsing on for an instant revealing
    an image briefly and then shutting down to black and then turning back on again cycling at about 1/2 second intervals. It does this indefinitely. How can I address this question directly to Expert BUDMRTN?
    Thanks to All responders so far.
  • 942 Answers
It might be the power supply or the video card that has the problem. You could either reseat them after you turn off the pc.. If still did not work, then thats the time to have your pc check for repair....
Posted on May 31, 2010
    Genius:
  • 1,354 Answers
Hi
you have prob with resolution
on desktop right click of mous
1 properties
2 settings
3 screen resolution ( 1280 by 800 )
4 color qulity ( 32 bit )
do this setting and try hope fully it will work if not contact me
  • hi
    in this isuue i thing you have prob with VGA cable with is from monitor to CPU
    in LCD monitor there is only one small board in monitor most of the time cable giveing prob
    chak with locale technition to change cable
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with if you have warranty then use it and get it repaired to avoid future issues. However, if you dont have warranty then you can open the monitor and start checking the power board which is the board where power cord/plugs goes in as it seems you have checked everything else out. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 30, 2010
  • Rylee Smith
    Rylee Smith May 31, 2010
    You are right, this can happen due to these capacitors and/or a backlight issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
If i select source to pc display will become blank and power indicator blinking.
• You can check if the product is working properly using the Self-Diagnosis function.
• If a blank screen is displayed and the Power LED blinks even if the product and the PC are properly connected, perform
the self-diagnosis function according to the procedures below.
1. Turn the product and the PC off.
2. Separate the signal cable from the product .
3. Turn the product on.
4. If the product is working properly, the message appears.
In this case, if a blank screen is displayed again, make sure that there is no problem with the PC and the connection. The
product is working properly.
Is a blank screen displayed and does the power LED blink at
a 1 second interval?
1. This occurs when the power saving function is running.
If you click the mouse or press any key, the screen will be
turned on.
2. This occurs when two monitors are connected,
is and Magictune is running. In this
case, characters on the Magictune OSD may appear
corrupted. To run the Magictune, the must
be set to . Please restart your PC, set the
to and run the Magictune.
Jul 07, 2011 | Samsung BX2231 21 inch Monitor
DGM screen monitor problem ''22
the light blinking makes me think that the moniter is going in to sleep mode...try turning the computer on while the moniter is not pluged in(pull the blue vga cable) wait a bit then move the mouse around then plug the vga coble back in...(while the screen is already on)
Jul 09, 2010 | Computers & Internet
Monitor is blinking and then went blank
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 12, 2010 | Emprex LM2201 22" LCD Monitor
Lcd montor not working help
Symptom : No images on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power cord connecte properly.
Action : Check the power cord connection and supply.
Checklist 2 : Can you see "Check Signal Cable" on the screen ?
Action : (Connected using the D-sub cable)
Check the signal cable connection.
Checklist 3 : If the power is on, reboot the computer to see the initial screen (login screen), which can be seen.
Action : If the initial screen( the login screen) appears, boot the computer in the applicable mode (the safe mode for Windows ME/XP?2000) and then change the frequency of the video card.
Note : If the initial screen does not appear, contact the Service Center or your dealer.
Checklist 4 : Can you see "Not OPtimum Mode", "Recommended Mode 1440 X 900 60 Hz" on the screen.
Action : You can see this message when the signal from the video card exceeds the maximum resolution and frequency that the monitor can handle properly.
Adjust the maximum resolution and frequency that the monitor can handle properly.
Checklist 5 : There is no image on the screen. Is the power indicator on the monitor blinking at 1 second intervals ?
Action : The monitor is in Powersafe mode.
Press a key on the keyboard activate the monitor and restore the image on the screen.
If there is still no image on the screen, press the On button. Then press any key on the keyboard again to activate the monitor and restore the image on the screen.
Hope this helps.
Have a good day.
Dec 08, 2009 | Samsung SyncMaster 920NW Monitor
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Soyo TFT 19" LCD Monitor Logo
115 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
