Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaide Superba side by side - 4 years old. I've been having this issue for over 2 years now. Ice maker makes ice, but there is ice build up around the base of the hopper (bin that holds the ice) and water trickles out the dispenser in the door. I have removed, cleaned, removed all built up ice, pre-cooled and replaced the hopper numerous times. Initially seems better, but problem recurs. I paid $150 last summer for our local reputable appliance service folks to come look at the problem, told me nothing was wrong with it.
  • 2 more comments
  • mbreiten May 30, 2010
    Kitchenaide Superba side by side - 4 years old. I've been having this issue for over 2 years now. Ice maker makes ice, but there is ice build up around the base of the hopper (bin that holds the ice) and water trickles out the dispenser in the door. I have removed, cleaned, removed all built up ice, pre-cooled and replaced the hopper numerous times. Initially seems better, but problem recurs. I have to keep a washrag underneath the dispenser and keep wringing it out. Sometimes this becomes so soaked the water runs down the front of the fridge and gets on the floor. I paid $150 last summer for our local reputable appliance service folks to come look at the problem, told me nothing was wrong with it.
  • mbreiten Jul 01, 2010
    Hey Phil, Well I finally got the replacement door chute. We are trying to see how to change it. Can you advise? It looks as though you have to remove the clear plastic shield first?? It also looks as though the chute just snaps out but we do not want to break anything.
    Marie
  • mbreiten Jul 07, 2010
    There is no evidence of ice build up or leaking anywhere in the ice maker itself. All the buildup is around the base of the hopper and in the ice chute. The suggestion by FixallPhil (see previous posts) seems to make the most sense, that the chute door is not providing a good seal and warm air is getting in.
    We have the replacement chute door and would like to try replacing it. We would like some advice on this. Do we need to remove the entire front dispenser plate? If so, what is involved in this? It looks like the chute door snaps in and out but there is also the plastic shield (guide ice) in the way without removing the front plate.
    Marie
  • mbreiten Jul 09, 2010
    I keep waiting for someone to give advice on how to install the replacement chute door which I ordered. It's as if you all don't have access to the thread I have going. The suggestion that warm air is seeping in through the chute door fits the problem very well. We want to replace the chute door but would like some advice on how that is done.
    Frustrated!!
    President:
  • 1,197 Answers
Yes the ice buildup is coz of a problem in the defrost cycle... and u wud be required to test all the three components.....
first we ll see how u need to check the defrost timer....
Before testing the defrost timer, unplug the freezer to avoid an electrical shock hazard.
A mechanical defrost timer controls the defrost cycle of the appliance. In older models, the timer runs continuously and roughly every six hours, shuts off power to the cooling system and sends power to the defrost heater. In newer models the timer advances only when the compressor or defrost cycle is running - an improvement for efficiency. As the timer advances, power to the heating element shuts off and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrosttimer is usually found behind the front grill of the freezer. It mayalso be found behind a cover plate inside the freezer, in thetemperature control console, or behind the freezer near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
clik here for images
Test the timer for continuity using a multitester.Set the multitester to the ohms setting X1. The timer has fourterminals. Locate the common terminal, it should be labeled "3" or "C".If the terminals are not labeled, determine which terminal coincideswith the common wire in the connector plug; it is usually the whitewire.
Once you havelocated the common terminal, touch one probe to it. Touch the otherprobe to each of the three remaining terminals. The multitester shoulddisplay a reading of zero or near to zero ohms (which indicatescontinuity) for one pair of the terminals and possibly two pairs. Thethird pair of terminals should show no continuity (infinity).
Locatethe timer switch and turn it clockwise until you hear it click. Nowretest the timer as you did above. One pair of terminals shouldindicate continuity (possibly two pairs). At least one pair should givea reading of infinity. Note however, one of the pairs that showedcontinuity in the first test should now read infinity and one pair thatread infinity should now show continuity. If the defrost timer does notpass these tests, it is likely that it should be replaced.
* We have received two reports of cases in which only one pair of terminals shows continuity and when the timer is advanced, the same pair still shows continuity. For these isolated cases, this was reported to be the correct operation of the timer. At this time we have not been able verify this case. This may indicate a specific model or models that use a different wiring configuration than discussed in this article. Also, note that this article applies to mechanical defrost timer controls and not electronic or adaptive defrost controls.
now we ll see how we need to check the defrost heater.....
Before testing the defrost heater, again make sure u unplug the freezer to avoid an electrical shock hazard.
The defrost heater is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear or bottom inside panel of the freezer.
The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver.
There are three primary types of defrost heater elements; exposed metal rod, metal rod covered with aluminum tape or a wire coil inside a glass tube. All three elements are tested in the same way.
The heater is connected by two wires.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Test the heating element for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading somewhere between zero and infinity. If the reading is not between those two extremes the heating element should be replaced.
this is how u check the thermostat.....
A defective thermostat can prevent the defrost heater from coming on or allow it to overheat which could result in heat damage or fire.
The panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. On some older top freezers it is necessary to remove the plastic molding to access the freezer floor. Removal of that molding can be tricky -never force it. If you decide to remove it, you do so at your own risk - it is prone to breaking. Try warming it first with a warm, wet towel.
The thermostat is connected by two wires. The wires are connected with slip on connectors or a wiring harness. Firmly pull the connectors or harness off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the thermostat for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading of zero when the thermostat is cold and a reading of infinity when it is warm (40 to 90 degrees F depending on the model). If the thermostat does not pass this test it should be replaced.
Posted on Jul 10, 2010
  • 3,083 Answers
Somehow, it sounds like you're getting condensation on the bottom of the hopper. I'm wondering if time timer control board isn't waiting a bit too long to cool the freezer, and there is a slight melting problem. Not sure. However, for the leaking problem, a tech on FixYa has the answer for the water leaking:
http://www.fixya.com/support/t1505115-in_door_water_dispenser_leaking
I tried searching the net for the hopper ice problem, to no avail. Still seems like a cycling issue, however.
Posted on Jul 07, 2010
  • 2,272 Answers
The ice cube section comprises the ice cube maker, the hopper, and a tube connecting the hopper to the door. The hopper has an auger that pushes ice towards the front door. At the front of the ice cube hopper is a device that crushes ice, if you choose to have crushed ice. The icemaker will make ice until you turn it off, or until the hopper fills up. A clever metal wire is pushed up when the ice cube hopper is full. Also check this wire.If this wire is not getting pushed up automatically as per the system then ice will start getting buildup. Please check the valve from where the water is entering in from to make sure that it does not have an ice build up in it. If it does you will need to remove that valve because it is on a timed basis but if this is frozen the water will just trickle in and doesn't always shut off. The valve could be the fault of the concern even if there is not ice. This valve is what opens and closes to allow the water to enter into the ice-maker. In some cases the Ice-maker itself needs replacement. Check that ice is not stuck in the ice chute. The ice chute can build up ice flakes over time due to the use of crushed ice. The ice chute is located on the inside of the freezer door and is accessible by removing the ice storage bin. Use only a plastic utensil to remove ice from the ice chute. Do not use anything sharp to remove ice as this may damage the ice chute.Once large clumps or cubes are removed, use a warm, wet cloth to wipe the inside of the ice chute. After removing the ice build-up, dry the ice chute by wiping it with a clean, dry cloth to prevent additional ice formation.
Check that ice is not clumping or sticking together in the ice bin. If it is, shake the ice bin to separate the cubes. If the cubes do not separate, empty the ice bin and clean it. Allow 24 hours for the ice bin to refill.
Check that ice is not melted around the auger. The auger is the metal spiral object in the ice bin. If it is, dispose of the ice cubes and clean the ice bin. Do not try to remove the melted ice with a sharp object as this may damage the ice bin. Allow 24 hours for the ice bin to refill.
  • Ice clumping in the bin or around the auger may be a result of the freezer door not shutting completely or the ice chute door being stuck open. Check that the freezer door is closing completely and that ice is not stuck in the ice chute.
The manufacturer recommends regular inspection and cleaning of the ice chute and the ice bin to prevent ice build-up. This inspection should be done approximately every 2 weeks.Kitchenaide Superba side by side - a599a47.jpg
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    President:
  • 949 Answers
It sounds to me like the dispenser door is not sealing properly. If this flapper door is not tight, warm moist air will be drawn to and condensate on the cold surface of the ice bin.
To check this, open the freezer door, take the ice bin out. Turn the kitchen lights off and have someone shine a flashlight up the chute in the freezer door while you are looking down from the inside of the door, if you see light then the ice door (part number 2180353) can be replaced. It has a built in heater in this door to help it seal better.
Let me know what you find and we can go from there.
Phil
Posted on May 30, 2010
    There is light showing, so we will order this part and see if it resolves this.
    Thank you.
  • Philip May 30, 2010
    You are welcome
  • 787 Answers
This is normal behavior. However, you may want to go easier on the ice ... extensive usage of the ice dispenser usually has this side effect.
    I don't see that it is overuse, if anything, it's underuse. I use it once or twice a day, perhaps a few more times on the weekend.
    I don't see how this can possibly be normal. I have to keep a washrag under the dispenser at all times. This has to wrung out and sometimes gets so wet it starts running down the front of the fridge onto the floor.
  • Tudor Valean
    Tudor Valean Jul 07, 2010
    Well?
Kitchenaide superba icemaker won't shut off when full
Is this one that has an ice bucket that sets on the freezer door. If so it has an electronic eye that senses if the ice has accumulated enough to be stopped. This eye assembly may need replacing. It is just inside the freezer door and both sides come in a kit.
Aug 17, 2014 | Refrigerators
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
Jul 08, 2017 | KitchenAid Kitchen Aid Superba Series...
Ice maker not working at all
We defrosted ours and it came back 2 life
Sep 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
No ice
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker's ice taste funny
You may consider pulling out the ice maker and tossing it in the trash if you look at it and see that where the ice sits it's corroded or its close to a 10 year old in age (IT'S DUE TO GO OUT ANYWAY).Other than that:you have a 3% chance that the tube that goes to your ice maker is bad. Please Rate This !
Jun 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaide fridge side by side
Replace the module on the ice maker. Its the front square part on the IM remove the cover and you will see it. Always unplug before messing with electricity. If the IM is old replace the unit. The module could cost upto $75 or more. If you wwasn't getting good water flow you would replace the water valve.
Nov 05, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
106 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
