I have a aiwa cx nds50u and my tape deck wont play When I turn it on it makes about 4 clicks and nothing it will tell me tape 1 or tape 2 but thats all. ???
bmwrider
  • 215 Answers
SOURCE: Tape Deck
Really simple one this. You have a slipping belt. Don't try to use any more tapes in it, you end up chewing them up. I change all my belts in my decks every 2 years due to the extreme heat we have here. Unless you know how to strip the unit and can get hold of the correct belt I'm afraid it's a repair shop job. BMW To give you some idea of price I charge $50 for a complete service, alignment and belt change.
Posted on May 22, 2006
fairlane
  • 50 Answers
SOURCE: tape decks playig too fast
Hi I can probably tell you what is wrong, but there is usually not much you can do except take it to a shop and have the motor replaced. I most cases there is a hole in the back of the cassette capstan drive motor, or on a small circuit board close to the motor where the speed is adjusted at the factory. You could possibly adjust the speed by ear until it sounded right playing a factory recorded tape with a song you know well, but I recommend these adjustments be left to a tech with a frequency counter. Also, these adjustments normally never need to be touched unless replacing a motor, so it is likely something internal has gone wrong with the motor, and it should be replaced under most circumstances. Hope this helps, Good Luck.
Posted on Sep 27, 2007
SOURCE: Clicking sound in tape deck
All Aiwas  are prone to this problem.  The doors are a real pain and easily give up the ghost.  I have 2, both probmatic in this direction.
I have spoken to others about this problem. Seems no easy fix.
Have you in your case, tried leaving and old tape in the tape part of your  unit . The noise you hear, usually starts when tape unit area doors are about to pack a wobbly. Unless under warrenty, proberly,
not worth getting fixed.    It seems something gets weak in the activation part and get a mind of its own.  Very common after about 3 yrs of ownership.  All the best: jamz
Posted on Oct 25, 2007
robotek
  • 1512 Answers
SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Posted on Dec 09, 2007
  • 4234 Answers
SOURCE: I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Dan
Posted on Feb 23, 2010
How to get a tape to play on a aiwa cx-na888?
Put the tape in and hit play. If that does not work then off to the repair shop.
May 26, 2014 | Audio Players & Recorders
Aiwa cx-na71 tape decks will not run
your capstan belts are probably dried out and need to be replaced.
Feb 15, 2013 | Audio Players & Recorders
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
Technics tape deck rs-eh600 wont play it just clicks
Another dual deck it seems- the unit will need service by a Technician, there is no magic that will make it work. It may be as little as a large belt. I would have to see the unit to tell you the exact cause.
Aug 13, 2012 | Technics Audio Players & Recorders
Tape slots won't open and nothing is functioning.
you need to replace your belts, go to partstore.com, punch in your model number and it will give you the correct belt's that you needed
Jun 06, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
My Aiwa cx-nma545 keeps turning off.
Your system is in 'Eco' mode. If you are in this mode, and go 10 minutes without playing a CD or cassette, it will automatically turn itself off.
Here's how you get out of 'Eco' mode:
1) Go to the jog wheel assembly
2) Press 'Eco'
3) Press 'Enter'
4) The display will show "Eco Mode On"
5) Immediately turn the jog wheel, to turn the status from 'On' to 'Off'
Feb 08, 2010 | Aiwa NSX-DS55 CD Shelf System
Tape deck problems Aiwa CA-NSX777
Tape drive mechanism requires service (cleaning and lubrication) and might need replacement of drive belts. Of course its qualified tech job.
Jul 25, 2009 | Aiwa NSX-A777 Shelf System
How do I record from one tape deck to the other?
Put your "blank" in the deck with the record button, normally red button and press rec/play and pause at the same time, put your "origional" in the other deck and press play and pause at the same time, then un-pause both at the same time. Make sure that the hifi is set to tape as if you record tape to tape when listening to radio foe example, you will get a strange "mix tape" of your origional and the radio.
Jun 05, 2009 | Audio Players & Recorders
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Tape deck does nothing when play is pressed
Maybe a problem of no power to motor. I own 2 identical Aiwa units, both have tape deck problems. This brand is prone to them They also have nasty habit of tape cassette doors jamming.
1st off you never said how old the unit is. Awia have huge amount of models. Mine are the NX series that came out in black plastic. Most of the others are silver/grey. Honestly, unless you pop side screws and lift the cover off to eyeball anything loose. and none is? And if out of warrenty, the value of fix, mat exceed value of unit.
Sorry, but I see many of these,  of 4-5 yr old units Aiwa brand,
get the heave ho!
The most stupid thing about this is: for units size, has the best sound of any other brand it's size.. Brilliant for hooking to ones TV sets, for  surround sound!
What I did was get an older getto blaster  that plays tapes to play my tapes on. some of these units are around and in good order, dirt cheap. And most electronic equipment problems cost at least $35  just to have a quick look at your unit.. cost of repair on top?  I brought my 1st one new @ well over a grond. 3 yrs later, 2ns one, exactly the same $15.00 in a charity shop. The  laser unit was dusty. All go in half an hr. Perhaps if it is an older model , look for another mate to it,   It all comes down to costs.
Which is better option... you are the one who has to made the choice. Good luck. Jamz
Oct 25, 2007 | Aiwa NSX-AJ20 CD Shelf System
139 people viewed this question
 Grubhead
Grubhead
