1984 chevy truck;Just got truck painted, need wiring diagram to get working correctly, right now the power window switchs operate the power locks. I have found two wiring conections not plugged in where the main wires come from the doors above the steering colum and cant figure out where they go.
Haynes repair manuals would have good wiring diagrams. Or google it, you can find about everything on the internet, but sometimes a problem with too small of print, or maybe my computer skills need sharpening.
I don't know about those wire connections not plugged in. Are you sure they are from the doors? Can't imagine what they would be.
SOURCE: nned steerin column diagram
I don't have a diagram, But I have taken tons of these apart. Is there something I can help with?
SOURCE: door locks
Not to insult your intelligence or anything, but I had the same problem, and fixed it by replacing fuse #13. It was caused by a short in my cigarrette lighter. Good Luck!
SOURCE: ive changed the ignition switch and checked the
Do you have ballast resistor on firewall by chance? ( 2"x 4" ceramic like block,usually held with 1 bolt in center)
SOURCE: i need the correct spark plug wiring diagram for a
Firing order is 1-8-4-3-6-5-7-2 and the rotor turns for clockwise. If you look at the distributor cap the Above
SOURCE: need to know how to instal the horn contact and
First you need toremove the steering wheel. You will also need a lock ring removal tool. This tool will help you remove the circlip from behind plastic cover. Dont lose this clip.After you have removed the lock plate then the horn ring should be visible and you can replace it.
