Question about Home Security
Battery installation Have a fire alarm panel, the sealed battery was installed in a vertical position is this an acceptable installation?
    Sniper:
  • 54 Answers
Yes, this is acceptable. As noted the battery is of a sealed lead/acid variety and is designed to work upright or on it's end. I have installed batteries this way many times before when space is limited. Hope this helps.
Posted on May 30, 2010
Brand new Kidde smoke alarm keeps chirping after installation and reset.
contact the installer for advice
read the user manual for faults
could be that the battery is not fully charged yet
Nov 27, 2016 | Computers & Internet
In new 3-alarm system just installed by electrician the alarms issue 3 long beeps and "FIRE" about every 10 minutes. Kidde is not available to help. Can you?
I think it could be one of three things.
The electrician may not have installed the back-up batteries.
The electrician may not have turned the primary power to the detector circuit on when he completed the work and now the battery is depleted.
The electrician may have tied the the detectors into a switched circuit which does not apply constant primary voltage.
Hopefully you can contact the installer to troubleshoot his work.
Feb 13, 2016 | Kidde i12040 Hardwire Smoke Alarm with...
We replaced the batteries but the alarms are still beeping with the low battery warning.
Either the new batteries are out of juice, or they have been installed incorrectly.
Jun 06, 2014 | Universal Security Instruments Smoke Alarm...
How to install a wired fuse between battery and amp
Fuse rating is based on the guage of wire it's to protect.
Install the fuse holder close ...within a foot...to battery positive connection.
You may require a different battery cable clamp to accept your new amp wire (and the existing wiring).
Occasionally, it's possible to use an unused location in a vehicles power distribution panel (the fuse box close to the battery - under the hood). Sometimes appropriate for small to mid-draw amps, in certain vehicles, where some high draw options were not factory installed.
Mar 16, 2014 | Car Audio & Video
The 2002 Dodge Grand Caravan starter would crank yet the engine would not fire; before this situation, the battery had died; after cleaning the battery terminals & charging the battery, the starter did...
First, check all the fuses in the interior fuse panel. I believe that one is located just under the left knee area of the dashboard or behind a hidden panel that you access on the side of the dash when the drivers door is open. Second check all the fuses and relays in the power distribution box under the hood, drivers side near the air cleaner box. If all fuses are good, I make it a point of checking the timing belt. The easiest way to do that is do a compression check. If the timing chain is broken you will not have any compression on several cylinders. If you have a fuel injected motor and you should, at the end of the fuel rail(s) there is a black cap and when you remove that you can put a pressure gauge on it and check your fuel pressure. Make sure the ignition is in the on position when you check it. Finally, if everything else checks out replace the coil pack which has the ignition coil built into it. Now all of this assumes you do not have an alarm with a starter kill switch or anti theft device installed. If you have an alarm installed on the vehicle that is not factory equipment, disconnect the main power wire for the alarm and try starting.
Sep 24, 2011 | 2002 Dodge Grand Caravan
I need instructions for my timex clock
Hello
Here are the instructions for your clock-radio.
Installation
1* Remove unit and all packing materials from the carton. You should save packing
materials in case unit needs to be returned for service. If you do not wish to save the
materials, please dispose of them properly.
2* Place the unit on a stable, level surface, close to an AC outlet, out of direct sunlight,
and away from sources of dust, dirt, heat, water, moisture, vibration, or magnetic fields.
3* After installing the batteries (see below) and reading the Maintenance notes, plug the
AC cord into an outlet.
"Sure Alarm" Battery Backup Installation
It is strongly recommended that 2 "AA" batteries be installed into the unit, as directed below,
in order to activate this product's "Sure Alarm" Battery Backup feature. (The model should
come with two batteries already installed.) In the event that the AC power cord is disconnected
or a power failure or other interruption occurs, the "Sure Alarm" Battery Backup will maintain
clock and alarm settings for the life of the battery, ensuring that the alarm (buzzer only) will
sound at the set time. During any interruptions the time and alarm settings will be saved
and automatically restored when AC power is again active.
1* Gently turn the unit over and remove the battery
compartment door.
2. Install 2 "AA" batteries (alkaline is recommended for
longer life), while making sure that the + and - ends
match up with those inside the battery compartment.
3* Slide the battery compartment door back on, making
sure the door locks into place, and gently return the
unit to its upright position.
Aug 19, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
I accidentally locked myself out of my Smarthhome Securelinc Alarm Installer Code Model OH-41073AT. I would like to reset the unit to my installer code or create a new one. Can you assist?
The first thing to try would be to disconnect the mains supply and remove the internal battery for a minimum of 5 minutes and then reconnect it.
If this doesn't reset the system then remove the mains supply and battery again for another 5 minutes.
After 5 minutes reconnect the battery.
Then with the help of a friend try holding the # & * keys while they turn the mains supply back on.
These are generic resets for most house alarms but I'll keep looking if there's a specific one for your system so if neither of these work just let me know.
If I find anything else in the mean time I'll add to this post.
Jul 06, 2011 | Visonic INC Smarthome SecureLinc Wireless...
Do you have instructions on how to change the battrery in a 2001 VW passat GLS?
Battery lives under windshield forward plastic panel and can be removed by peeling off the fire wall compartment seal to release the cover.
Put car in P or neutral.. remove ignition key. Obtain your radio code from records you have or dealership.
Open hood.
With 10mm wrench disconnect GROUND negative clamp on battery.
Ditto to Positive clamp. ( Do it in this order !.)
With 10mm socket, undo battery holder clamp in front of battery and lift away clamp and nuts.
Lift away battery.
Install new battery fitting the Positive battery clamp first then other parts as removed.
Do not bounce the GROUND battery clamp on the battery post as you install it as this can cause electrical damage to on-board electronics.
Jan 13, 2011 | 2001 Volkswagen Passat
Why alarm only works when close to car
Poor range can be caused by a number of things. Has this problem only been occurring recently? If yes, try replacing the battery in the remote transmitter since a weak battery can be a problem. If this is a new install, bring it back to the installer to have them check it. Other possible causes can be improperly positioned antenna, the alarm brain installed too close to an electronic control unit, the alarm brain mounted to a large ground plane or a defective alarm brain.
Oct 22, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
Hi! I was installing a connector for charger when I accidentally touched the frame of the bike with the allenkey while opening the battery positive contact. ever since i have ignition lights but no...
blown fuse buddy find the fuel box and find the black fuse this will happen as if the fuse didnt blow soon enough the battery would catch fire its the same fuses as a car
Oct 21, 2009 | Honda VTX 1800 C Motorcycles
Home Security Logo
129 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
