Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
My power suplly is broken and i cant use my xenyx1002fx. can i order a new one?how mach it cost?
  • Behringer Master
  • 5,603 Answers
Broken pins are common on these power supplies. The units are hard to find. If yours only has broken pins in the connector, find the connector type and have it replaced. Fifeteen minute job...
They probably use MINI DIN types available from Digikey.com or Mouser.com.
Posted on May 31, 2010
Fix a Boss GT-10 broken input jack
what is your question?
if not working, you have to open the device and find out where it is not connecting (broken solder joint? bent or worn out contacts? wire off?) and repair. or if beyond repair, order a new part.
Feb 22, 2013 | Roland Boss Gt-10 Guitar Effects Processor...
The mixer has xlr main output x2 and jack unbalanced output x 2 can i connect 4 amps using this
The output jacks are PSUEDO balanced so use TRS cables and you should be able to drive two amps from each with no problem either as a WYE or daisy chained connection. The PSUEDO balanced connections do NOT drive differential voltages, but tie the return to ground through a 120 ohm resistor. It is imperative that you power ALL the amps and the mixer from the SAME receptacle or power conditioner. If you don't do this, expect lots of hum and risk of ground bounce damage to your equipment. Run extension cord if you need to.
Aug 04, 2011 | Behringer Xenyx1002fx 10 Channel Audio...
I got a Marshall MG100HDFX for free from a friend stating it was blown. I asked how this happened and he said that one of his friends plugged in another speaker or amp into the second speaker input in the...
The power amp section has blown parts. You will likely find they use a chip like the TDA7293 as the power amp output and it will be blown, shorted causing the fuse to blow. These cost $6 from Digikey.com. Find a competent tech to replace it and use heat sink compound. Verify the part before ordering one. They come with leads bent either way so make sure you get the one with a matching suffix letter. When firing up after repair, put a 60 watt light bulb in series with the hot power lead to act as a current limiter... saves blowing fuses if there is another problem.
Jun 21, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Help! I have a yamaha psr 9000 keyboard - i've had it for almost 9 years and my dog has chewed the ac power cable. Is it still possible to get a new one to fit it? If, so where can i buy on line? I...
Your main's power cord is easy to found at most of the electronic shops. It's the typical "figure of 8" connector, available also for some laptop's power supplies. You can also order one one line from this link. Note that since I don't know where are you from, the plug for the wall-socket may differ from the one on the provided link, but it's easy to use an adapter for your local area electricity. For example if you leave in Europe you can order the power cord from this link that is fitting on the european electricity standards. In case you can use screwdriver and cutting tools you can also change just the plug for the wall socket (in case that the dog's chew is near this plug) with very low cost.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Apr 12, 2011 | Yamaha Music
There are times when I power up the Central Station, and when the audio is going, the LED meters don't work. I've tried power the CS down, wait, and power up again and it doesn't work.Still no LEDs moving....
Same thing has just happened to mine !
First thing I noticed this morning was the LED display was stuck on FULL... I unplugged it...and restarted...still the same...repeated that..and now NO LEDS at all ! WTF
Feb 08, 2011 | PreSonus Central Station Studio Monitor...
B212D powered speakers internal amps damaged by power surge in our home. Can they be replaced with new amps and what would cost be. johnssale@gmail.com
Cost by replacing the amps would NOT be cost effective.
In looking at the schematic, assuming there was a voltage surge on input power, possibly the diodes and capacitors in the power supply are damaged if the fuse blew and was replaced.
If the speakers were powered by a different receptacle than the source feeding the audio to these was, ground bounce may have destroyed the first input stage.
You need to give us current symptoms so we can direct replacement of bad components.
Dec 14, 2010 | Behringer B212D Powered Speaker (550...
Amps in my B212D powered speakers were damaged by power surge in our house. Can I have new ones sent to me and I will remove the old ones and replace with the new. What would the cost be in Canadian...
The parts cost I suspect would be about 1/2 of the new cost of the units... certainly by the time you add shipping cost... Find a competent repair shop.
To get the parts you would need to first call Behringer 1-425-672-0816 to get a part number and an incident number, then deal with FullCompass which distributes the Behringer parts.
I have a Peavey PV 2600 amp, when it is switched on only the fan works but nothing else. It is three or four years old and it was given to me by a friend, roughly how much would it cost to repair and get...
Either have it fixed or offer it up as broken at auction.
Estimating cost is near impossible, however labor could easily be aver $100.
The fan is controlled by a rather complex circuit depending on thermistor temp sensors. The temp sensors appear to also shutdown the amp.
If the fan comes on instantly, there MAY be a failure in this circuitry which is inexpensive parts...
Each side of the amp has 10 major power transistors and if all were blown it would add significant parts cost to the repair.
Aug 18, 2010 | Peavey Pv 2600 Power Amplifier
Just bought Kingston 2GB SD Card for Boss Micro BR but when maching turned on,its frozen on KEEP POWER ON! SONG LOADING!
This is likely a compatibility issue. Turn power off and remove the card and make sure the unit comes back to life.
SD card compatibility can be a problem.
You might want to go to VSPLANET.com as there is a lot of info on forums about recorders.
Jun 03, 2010 | Boss Micro BR Digital Recorder
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
157 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
