Question about Brother MFC 240C All-In-One InkJet Printer
Printer keeps telling me that I need to replace the Cyan cartridge. the cartridge has been replaced and yet I still get the same message.
  • 8,404 Answers
Is this a genuine Brother cartridge? Is there a feature in the driver that will allow a reset?
Posted on May 30, 2010
Install cyan
That message is saying you need to replace the blue "Cyan" ink cartridge in the printer. When the printer detects that the ink in out it tells you to replace the empty one to continue printing. Just buy a new cartridge install it and you will be good to go.
Jun 29, 2013 | Brother MFC 210C All-In-One InkJet Printer
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
When I replace the cyan cartridge with a new one I keep getting the message"No Cartridge"
hi!!! in that kind of problem maybe the sensor of the cartridge was damage thats why the sensor cannot detect when you install the cartridge. Try another cartridge or maybe try the to re-install old one if the printer detect the old cartridge that means the new cartridge was defective. Thanks
May 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
Cyan ink Cartridge
Do you use generic ink carts?
If yes, try another one.
Alwasy make sure that the carts are placed well and are secured.
Answer the lcd question given by machine and check the magenta and the BK one, which could be empty, too!
Dec 28, 2007 | Brother DCP-315CN All-In-One InkJet...
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Brother MFC 240C All-In-One InkJet Printer Logo
97 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
