Question about Canon PIXMA iP3000 InkJet Photo Printer
Printer problem Hi im jen, and i got a probelm on this Canon Pixma ip1300. It doesnt print at all it indicates "INK ABSORBER IS FULL CONTACT SERVICE PROVIDER". the green and orange indicator light simultaneously.... pls help me here. Is there any parts to be replaced off or is the ink absorber can be replaced?
  • 1 more comment
  • dirkpeter Apr 19, 2008
    my Canon PIXMA iP3000 InkJet has also problem it has an overflow of back ink !
    is there a solution !
    (soory for my bad english ! i,m dutch.
  • vashi Apr 19, 2008
    Hi, my printer is giving me a message "INK ABSORBER IS FULL CONTACT SERVICE PROVIDER". This is the third time in two years. Previously I replaced with a new printer but this time I had used just for eight months. Is there any solution for this? Please help.
  • Ralftodd Apr 21, 2008
    Canon Pixma IP3000
    I did receive a message that the ink pad was full of ink. So I took the pad out and cleaned it and replaced it. The yellow light now flashes 7 times. What should I do next? Ralph
  • Canon Master
  • 5,568 Answers
The ink absorber (a felt pad) is provided so the ink lost during cleaning has a restricted area to ensure the ink doesn't escape into mechanical areas of the printer.
I haven't seen the inside of your model but this is probably being monitored using reflected light and once the reflection is reduced (pad changes from white to dark) this warning is triggered.
The printer has been disabled to avoid cast-off ink from overflowing the recess in which the pad is installed.
Unless you are very good at finding the sometimes many snaps that hold your printer together, it should be turned over to a professional.
As a retired tech, I need to warn you that the cost of labor and the pad needed will probably exceed the cost of a new printer.
If you decide to replace it, be advised that most printers are supplied with only minimal amounts of ink in their included ink cartridges; please consider buying cartridges along with the printer to have available when the original cartridges run dry.
Posted on Apr 08, 2008
In printer canon ip 1800 is showing ink absorber is full cant use the printer
Hope you find this information helpful.
The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer. Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 31, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is almost full problem is for cannon 1800
Hope you find this information helpful. The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing.Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 23, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Jul 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Its appear " The ink absorber is full. Contact the service center."
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 11, 2009 | Office Equipment & Supplies
MY PIXMA iP1300 keeps error
since canon printers need service tool to reset the waste ink counter, i suggest that you bring your printer to an authorized service center in your area to have them reset the waste absorber counter and clean it as well.
Feb 15, 2009 | Canon MP610 Photo All-In-One Printer
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
ERROR MESSAGE 2
How do I change the ink cartridge for the Canon Pixma 150
Sep 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma ip1300 Ink absorber is full what can i do
another solution for a quick override is to unplug the power lead from the back of the printer. With one hand hold down the power button on the printer whilst simultaneously plugging back in the power lead. When the light is back on, take your finger off the power button. You may need to press the power button once more, but this should 'override' the problem until the next time you turn your printer off.
Mar 26, 2008 | Office Equipment & Supplies
Canon PIXMA iP3000 InkJet Photo Printer Logo
148 people viewed this question
old marine
old marine
