Question about Sony RCD-W10 2-Disc CD Recorder
When i put in a blank disc and press record nothing happens
  • 3,083 Answers
The problem can be either the player or the disk. Not all disks, unfortunately, are compatible with all players (see Instruction manual that came with the player). If the same type disks have worked before, you can try to clean the laser lens with a qtip and alcohol. You can sometimes do this from the front, and sometimes you have to remove the cover. There are CD cleaners you can buy and insert, also. If you have no success with this, you will have to service the machine, or have it serviced. The things you can do yourself are shown and explained if you google the problem, and read the articles and watch the videos. It can be complicated unless you're technically savvy. The problem could be electrical, but is most likely mechanical. You can try to blow out any dust or debris that may be interfering with the operation, otherwise you will have to service it. Hope it's just some dust on your laser lens, and good luck.
Posted on May 30, 2010
Why doesn't it record to md?
You can't make a copy of a copy of a digitally recorded MiniDisc, so make sure that isn't what's happening- if so, it usually says "Din Unlock" and you can't record. I think when I record from one deck to the other digitally, I have set the recording deck to "REC", then I hit 'play' on both decks at the same time. Using the digital input, it should automatically set your track marks. You cannot make a digital copy of this MiniDisc, BUT you can make an Analog copy. Let me know if you need more info.
Dec 11, 2015 | Audio Players & Recorders
Have an acer laptop, using nero 7 burning software, have a tsst corp cd dvdw l632h burner - try to put iso files on to disc - used to work but suddenly it now says it has recorded but - disc is still blank...
There can be 2 possibilities:
1)the location of the recording is set to image by mistake and not the disc. if the location is set to image--then the files will be written to some folder on your hard disk itself .it must be given the proper disk location or path for files to be recorded on disc.this happens in most cases .
2)may be the lens is weak and the files are not actually getting recorded on disk.to verify this you can select the option called: "verify disc on data after burning" .this is the option you get just before you press the burn button.this will help you verify if the files are getting written on the disc or not.if the verification process fails then it means that the recorder has some fault writing to the disc.which needs to be checked and repaired
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 16, 2009 | Office Equipment & Supplies
When i put a blank DVD+R disc in the recorder the screen tell me. Please wait while disc is perpared. Nothing else has happen for 30 Mins the yellow bar goes all the across the screen. i then cannot get...
The first and foremost thing is that you verify that your dvd recorder is compatible with DVD+R discs and not just DVD-R.. This can cause the problem's you are having with it, you can check the manual to see what media types it accepts.
Post back with any further questions or info for additional assistance. Thank you for choosing Fixya!
Jul 18, 2009 | Daewoo Televison & Video
I get a "Data Disc" message when I press record.
have you purchased the correct blank discs? sounds like you've inserted discs that can only be used on a PC. these players can only record onto blanks bearing the "compact disc digital audio" mark. these are for use on home audio recorders. hope this helps?
May 02, 2009 | Sony RCD-W500C 5-Disc CD Recorder
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Jul 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Problem Recording HDD to DVD-R
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Jan 16, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Write error
I think i just figured it out. Somewhere else on the web clued me in that the disc got messed up (don't know how). I put in a new disc and it works. Other disc still doesn't though.
Nov 04, 2007 | Samsung SC-DC164 DVD Camcorder
I can not get my CD recorder to record
You should use consumer cd's that are rather expensive. You probably tried to record a recordable cd-rom (a cheap computer disc). It's not possible to burn a pro-disc (computer disc) by using your Pioneer, and that's why you got that message on the screen. Refer to the user manual of your cd recorder and learn what sort of blank cd you should use.
Aug 05, 2007 | Pioneer PD-R555RW CD Recorder
Sony RCD-W10 2-Disc CD Recorder Logo
42 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
