Question about Sony Playstation 3 (PS3) Console
When I push and hold the ps button on the remote the screen goes black and flashes
    President:
  • 1,469 Answers
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
Posted on May 30, 2010
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
I lost my viper remote starter, i already bought a replacement remote, but how do i progam it? I have the basic five button remote, black buttons and silver borders around the whole remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Dec 12, 2010 | 5101 LE 1 Way Car Remote Starter System
My sony SLV-D300P suddenly would not turn on. The blue ps button/light just flashes, but no attempt to turn the unit on works. It was working fine, without any problems, until this one occurred.
I have the same problem -- tried power reset, tried holding stop button for 5 second reset, nothing works. If I push the power button or the eject button, the blue light flashes momentarily then goes out.
Aug 28, 2010 | Sony SLV-D300P DVD Player/VCR
How to program viper 5701 remote
Unlock doors
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My playstaion3 turns on but all i get is a black screen. Everything is connected...the remote wont even turn the system on. If it does turn on the screen is messed up and it freezes.
Ok first of all take out the Hard drive (under a cover on the bottom of the PS3) and reinsert it. Then connect the remote with the USB cable and when asked press the PS button. If it still doesn't work you are going to have to download the newest PS firmware from the PS website, put it on a flash disk (memory stick), put it in the PS3 and follow the instructions on PS's site to update the firmware.
Aug 08, 2009 | Sony Playstation 3 (PS3) Console
Screen goes black
You tv is struggling to use hdmi so change your cable to a componet cable
Apr 06, 2009 | Sony PlayStation 3 40GB System
Ps button
Back up your system using the backup utility ( ONLY if you have saved games, pics, video, etc. that you wanna keep)
Go to SETTINGS, SYSTEM SETTINGS, RESTORE PS3
That's the first thing you should try.
Let me know what happens.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Need to program my chamberlain #953CB from a working gate opener
the chamberlin remote only work with a chamberlin reciever, if you have this it will be a silver box that looks like diamond plate material inside you operator, take of the front cover on this box and you will see a black button that says program push and hold this button down then push your remote button down while holding it close to the box you will see a yellow led flash and then it is set. if you only have a single button remote you will only be able to set it to one operator.
Nov 26, 2008 | Chamberlain 950CB Remote Control
Harmony 1000 Remote
Had the same problem.
My solution was.
  1. Boot remote into safe mode (Insert battery whilst holding down the power button)
  2. Update firmware from Logitech.
  3. Now this is the painful bit.... It will get to abou 42% then it will reboot. You wiil need to press and hols the power button down as soon as the screen goes blank. You will need to do this again at around 60%. If you select show details when updating the firmware you will see it say 'Rebooting remote'.
  4. Follow the remaining prompts.
Hope this helps.
Cheers
Jacko
Jul 09, 2008 | Logitech Harmony 1000 LCD Touchscreen...
Sony Playstation 3 (PS3) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
