Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
RE POST "in replacing push button switch INDAK 681064-01N I forgot to record the wiring sequence" This is kind of a weird one, but on the switch directly aboce the connector prongs, there is a brass rivet looking thing that holds them on, and the actual wire connectors have a slight rounded area on one side where the other is just flat, where when you push the wire all the way on to "snap" it flush with the connector it doesn't touch but if you flip it around the "bump" side actually touches these brass things... I blew one replacement swiotch by hooking it up wrong and now that I know where they go, I wanted to make absolutely sure that these brass connector/rivet things aren't important and whether I should make sure they touch the wire connector or not when I install it.... THANKS?!??!
2 Suggested Answers
SOURCE: in replacing push button switch
If you look at the switch with the pushbutton on the top, the white wire from the cord to the motor attaches to the upper left terminal, the red wire from the cord to the motor attaches to the lower left terminal (just below where the white wire attaches), the black wire from the cord to the motor attaches to the upper right terminal and the short black wire going to one of the two pins that plug into the extension cord attaches to the lower right terminal (just below the where the black wire to the motor cord attaches).
Posted on Jul 27, 2009
Want to replace 1998 ignition with aftermarket one....need to know color codes of each of six wires and where to place them on new switch.....thanks
I'm a Locksmith.. what kind of car ?? Mist us cars you just change the ignition in the housing... Forgien cars we pick them to the account and push a button and the cylinder is removed and a new one with keys pops right in.
But if you need to replace tge whole housing and it didn't come with a plug on the wires you may have to remove the old one and remove the wires from the plug and wright down what sequence they came out and put them back the same way
Dec 03, 2016 | Cars & Trucks
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
Disc tray cannot be opened
Hi, The unit is in initialization/reset mode immediately after powerup. It does a self diagnostic sequence. When a fault is detected, it actually locks up till the fault is removed/repaired. A couple of things you can do: 1. Unplug the unit from the mains for a couple of hours; 2. Check your manual if there is a hard/full reset sequence/button and perform it; 3. Remove the topcover and inspect the loading tray. There is a possibility that a CD is stuck, lodged or skewed inside; 4. There is also a possibility that the loading mechanism is stuck, defective belt/gear; 5. if the unit is still under warranty, require service or replacement; or 6. if no longer under warranty, seek the services of a qualified professional. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | iLO DVDRH04 DVD Recorder
Cub cadet starter engages as soon as you turn switch
It is the wrong key switch or the switch has gone bad. Inside the switch there is two round disk facing ech other, on them disk there is flat brass buttons, as you turn the key it touches them in to each other in a set order. so in the start position it connects the battery wire to the solenoid wire to spin the engine.It also ungrounds the wire to the coil Of course it goes through a bunch of safety switches getting there. I think there must be 50 to 100 different indak switches that look identical but the wires are in different order. So if there was two on the bench I would say you picked up the wrong one.
Mar 18, 2016 | Cub Cadet Garden
Machine will not start, replaced start switch now machine starts with the hot and warm button i think i have got my wires crossed
the start switch will just have a hot wire,, with a momentary closing when you push the start switch,, if you list the make and model of your machine, I'll try and find the wiring sequence for you
Jun 30, 2011 | Dryers
Is the button NC or NO? I have it currently wired this way but still it does not work and I'm using a switch not a button. Any suggestion?
The switch is OFF or NO normally open
See wiring diagram at following link
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
The way the timer works is this::
You click switch ON
When you turn switch OFF, the Dayton begins the timing sequence
The Dayton turns on the circuit going to load for 1/2 second => 5 minutes depending on model of Dayton timer
Grainger sells 120V push buttons if you don't want to turn the switch on-and-off each time
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=push+button+switch&op=search&Ntt=push+button+switch&N=0&sst=subset
http://www.grainger.com/Grainger/IDEAL-Push-Button-1XWT9?Pid=search
Oct 12, 2010 | Amperite Dayton Solid State Timer On Delay...
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
In replacing push button switch INDAK 681064-01N I forgot to record the wiring sequence, please help
Jul 11, 2009 | Black & Decker 19" Electric Lawnhog...
I need to replace the blower motor switch -'96 Nissan pu
Hey, I'd do an ohms test between voltage terminal suspect and l--m--h. If B and C terminals both have continuity to the speed terminals, I don't think it makes any difference which one is voltage.
I did look at 3 speed blower motor switch, different part number. C terminal was voltage feed to switch, B terminal was for lamp, just tells you it is turned on.
Type in your part number in search box, If you find it on a web site, maybe you can email manufacturer? The manufacturer can tell you which terminal does what?
Aug 21, 2017 | 1996 Nissan Pickup
Need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Apr 10, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
211 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
