Question about Sony PlayStation Portable (PSP) Console
Screen The screen won't show any pictures and it has a line going across the screen with a long crack you can still hear things.
  • 1 more comment
  • Anonymous Apr 23, 2008
    Yep same thing happens to me. IT consists of a large crack in the middle of the screen followed by vertical colored lines. YOu can still hear the music though.
  • vance james Apr 23, 2008
    the same thing
  • pspuser1 Apr 24, 2008
    I have the same problem. Just turned it on today and noticed the long crack. Seems weird we all notice it today?
    Problem Solver:
  • 7 Answers
Coicidently I have the same exact problem. Can you explain the events that occured before you recieved this error?
Posted on Apr 23, 2008
SOURCE:
Screen shows light with crack, cannot turn off
Internal defect needs factory service. Module inside needs replacing and you cannot do that.
Mar 25, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
While watching our set, after a few minutes, the picture on the screen condenses into a single line. You can stil hear the sound. Is the tube shot?
I would look for bad (cracked ring around pins) solder connections at the vertical output IC. Do not let play long with the line present or it will burn a trace across the face of the picture tube and you will never get it out.
Jan 29, 2011 | Toshiba MD20F51 20 in. TV/DVD Combo
KDL46W4100 no picture small white crack is visible when turned on. Crack got longer and eventually went across entire screen. People have told me the lcd is broken and it's not worth fixing - ie the part...
Yes, thats correct.
If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price.
New TV is better option.
Dec 16, 2009 | Televison & Video
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Lines across the LCD screen
Two things can cause lines across the LCD either horizontal or vertically. The first (and most likely) is a small crack in the display wafer. LCD stands for Liquid Cristal Display. They are very fragile and can be easily damaged if dropped. I broke one in my pants pocket.
The second would be if a pin on the ribbon cable (to the LDC wafer) was not making good contact. If you disassemble the camera it is possible to clean the contacts using contact cleaner (or alcohol). Only attempt this is you are willing to replace the camera if you don’t put it back together properly.
Mar 11, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
No Video
is the white line in the middle of the screen going left to right, if thats the case then sounds like a frame collapse, get it checked by an engineer
Feb 25, 2007 | Sony KP-48S35 48" Rear Projection...
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
