Question about Thermos Grill2Go Gas Grill 4656110
I need a gas pipe that fits the BBQ - Thermos Grill2Go Gas Grill 4656110
  • Thermos Master
  • 2,899 Answers
Try canadian tire
Posted on Jun 08, 2010
Need assembly instructions for a jackaroo flinders 4 burner bbq
It is a discontinued product so you are probably going to have to just lay all the parts out and guess. You could also look for assembly instructions for a similar BBQ made by Weber. They all follow a logical sequence.
I did find reviews, you could ask if anyone has the manual and when you ask a question, the question is sent to those who have reviewed already.
Jackeroo Flinders 4 Burner
Dec 28, 2015 | BBQ Guys Grilling
I have a ducane bbq and am having problems reattaching the gas line to the house
If it is push pull, on the house side pull back the gas pipe ring about 1/4 inch insert gas hose and release ring. If it is threaded, turn gas hose, bbq side, ring counter clock wise and it will attach.
Apr 24, 2014 | Ducane 30400042 (LP)
Hooked up bbq propane tank and smell gas?
I would turn the gas on and spray soapy water at the fittings if bubbles appear that is where your leak is. if it is leaking in the lines. turn gas off un screw fittings and wrap them with teflon or what some call plumbers tape they are both the same thing and very inexpensive. if it is at the valve on the tank I would get a different tank
Jul 26, 2012 | Grilling
Want to convert my Capt N Cook barbeque from propane to gas. Have the gas line already to hook up to barbeque but need to know what parts I need to replace and add to accomplish this Thanks
You need Natural Gas Burner orifices and perhaps, a new manifold.Also, a 12' long rubber quick disconnect hose (that's a Code Requirement) and all the necessary fittings. Contact your local BBQ Galore for the parts you need.
May 15, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Hi, I have a year old 12395 BBQ. Last week when using it for the first time I noticed a flame creeping down the rubber pipe, it appeared to be leaking gas from the side grill brass valve. I turned the gas...
Kevin, While I can't offer a suggestion regarding the cause of the problem, I'd like to stress to danger of a defective gas unit. A small LPG tank can explode with enough force to blow a hole through a wall. I'd suggest having it examined by someone qualified to service gas fittings.
Apr 26, 2010 | Grilling
Need to know if my cooker is a bayonet fitting
the bayonet fitting is on the end of the gas pipe that plugs into the gas main. look at the back of your cooker follow the black pipe you will see a brass end that fit to the solid gas pipe if you have a ring on the end of you flexible pipe that you can push in slightly and turn to disconnect you have a bayonet. its not the cooker that is a bayonet but the flexy pipe that is connected to your cooker. you can add one if one not fitted
Feb 02, 2010 | Belling Solitaire G755 Gas Kitchen Range
How to connect a N.G. bbq to gas supply line?
It is probably legal for you to perform work, check local codes or call local gas company first. If you've never worked on a gasline before, I'd recommend a professional to either assist you or hire. You don't want to chance a potentially dangerous or costly mistake. And when I say pro, I don't mean the guy in the plumbing dept. of the hardware store. I'm recommending a fireplace/ grill shop or asking your gas company if they provide this service. Good Luck, but play it safe on this one.
Apr 10, 2009 | Weber Genesis Silver B Grill
Thermos Grill2Go Gas Grill 4656110 Logo
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
