Question about Lands Phones
How to change the time on screen - Lands Phones
  • 3 more comments
  • Anonymous Jul 17, 2008
    How do I change the time on the avaya 18d corded phone? there is a feature button, but it doesn't tell what the features are. I think it needs a code.
  • Anonymous Oct 06, 2008
    ?? didn't help
  • nickname10 Feb 13, 2009
    Change Time!
    Change time
  • ktmarx May 22, 2009
    TOSHIBA DKT3010-SD
    Have no feature key and don't know how to find a menu.  Pushing buttons but nothing changes.
    More detailed instructions anyone????  Time Change for Idiots???  Bueller???
  • 871 Answers
Generic for all phones... the standard way to change the time and show it on screen is simply going to the settings and look for time settings... in here, you can actually change the time, the date , and the year and you can also change the time format form 12 hour to 24 hour.
Posted on Apr 08, 2008
On the T7316E
Log Into System Programming on the main phone:
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4
(Note: There's a programming card to place over the buttons on the right side buttons/display. If you don't have it, you will at least notice that after you have entered the password, the right button/display shows three upward pointing arrows. The first line arrow (upper right side) is SHOW, the arrow directly under it is NEXT, the second line left arrow is BACK. The first line left that doesn't have an arrow is "HEADING" or BACK to the previous main menu option)
3. Display will read: " Terminals&Sets >
4. Press NEXT to Time&Date
5. Press Show
6. Press Change
7. Use 24HR clock to enter time (i.e.4PM is 16:00)
8. Press OK
9. Click NEXT for Minutes, enter minutes, press okay
10. Press NEXT
11. Hang up to end session.
A. Configuration"
Using the navigation keys, as displayed below:
3. Press: NEXT Display will read: "B. General Admin"
4. Press: SHOW Display will read: "1. Sys speed dial"
5. Press: NEXT Display will read: "2. Names"
6. Press: NEXT Display will read: "3. Time and date"
7. Press: SHOW Display will read: "Time # # : # #" (Your current setting.
To Change the Time:
1. Press CHANGE; Display will read: "Hour:
2. Press CHANGE; Display will read: "Hour: _ "
3. Enter new HOUR. (in 24-hour format); Display show new.
4. Press NEXT; Display will read: "Minutes: # # "
5. Press CHANGE; Display will read: "Minutes": _ "
6. Enter the new MINUTES.
Posted on Jul 14, 2008
Did not help at all this information was common knowledge
Posted on Nov 03, 2008
Use the following procedure to update the time display on the Omega-Phone Model ZT-D:
Go to the main phone and …
1) Remove the handset
2) Press feature
3) Press speaker
4) Press 3
5) Enter the time using military time (e.g. for 2:05 pm, enter 1405)
6) Return handset
Voila!! J
Jennifer Booth, Montgomery, AL
Posted on Mar 18, 2009
SOURCE:
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
Jul 01, 2017 | Televison & Video
How can I set time?
You can set (or reset) your Time (& display format) using the "Menu".
From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
Look for, and tap on "Change preferences".
On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
Feb 11, 2016 | Tomtom One GPS
Military time
go to menu and change to 12 hr on clock
Mar 23, 2014 | Sceptre "32"" Class 720p 60 Hz Lcd Hdtv...
Date change
Click on time section of your start bar (bottom right of screen). Then choose adjust time and date settings.. Following on screen setups to change it over to correct date and time..
Jan 06, 2014 | Acer Computers & Internet
Can't change minute , day and date on shhors Lego watch
Whilst on the normal time screen; press MODE 3 times passing through STOPWATCH, and ALARM. Now back on the time screen; you should be able to press RESET to move through all the fields on the screen and ST/STP to change number/value. Pressing MODE once more goes back to normal time screen use. Hope this helps. Nich.
Aug 10, 2013 | Watches
Change time on screen
The time should change automatically, if not go into the tools or settings menu of the gps and try changing the time there. If that doesn't help, then try tapping the time on the screen and see if you can adjust it that way. I hope this helps.
Oct 06, 2009 | GPS
Changing time on screen
  • Press 'Prog' on the LCD screen
  • Enter ** (Star, Star)
  • Enter password (usually 1234)
  • Press 'Next' on the LCD screen until you see 'Date & Time Set'
  • Press Enter
  • You should now be able to change date and time
  • The arrow icon on the LCD screen allows you to move forward and back (press 'Shift' on the LCD screen to change the direction of the arrow)
  • Press SEL+ to change things like month and use the number buttons to change year, day, hour and minutes.
  • Press Enter and then pick up the handset and hang up to complete procedure
Dec 01, 2008 | Panasonic KX-T7630 Corded Phone
How do you change the time on a Panasonic KX-T7630 please. Digital Super Hybrid System
  • Press Enter
Screen problem
click start button
click controlpanel
click classic view
double click power options or settings depending on your operateing system.
If you have xp, change the time settings for suspend, hibernationg and so on.
If you have vista.
click on change plan settings on your current plan
change the time on: put the computer to sleep.
If you need more asistance, let me know.
Mar 12, 2008 | HP Compaq nx6310 Notebook
Lands Phones Logo
5,210 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
