Question about Vizio L32 32 in. LCD HDTV
Skipping thru channels uncontrlably
My tv keeps changing channels uncontrolably but if i press input and the main screen pops up it stops but the second i exit it starts jumping channels again what can i do or what is the possible problems atleast
trintek
  • 111 Answers
SOURCE: TV CHANGES CHANNELS (BY ITSELF)
is this tv the same model/brand? far be it from me to claim poltergeists are at work, but who knows... the very first thing i would do in diagnosing this issue is to grab some electrical tape and aluminum foil, tape a patch over the ir receiver for the remote, this should be a shiny piece of black plastic somewhere on the front of the tv, some are marked, some are not.. if you have it, aluminum duct tape works great for this purpose.
to me, it seems like someone is messing with you using a remote, tv-b-gone, or similar product like a keychain universal remote.. if the tape over the ir sensor fixes the issue, i would look at roommates, kids, neighbors, or possible interference from other ir or light sources..
possible culprits would be:
universal remotes
dirty remotes that keep sending a signal with nobody using it
laptops or cellphones with an irda port
palm devices such as palm, clie, etc that have irda
intermittent strobes (emergency vehicles, bad ballast in a light fixture, etc)
i can't guarantee this is your problem, but it seems like it since this is your second tv with the same or similar problem... as a sidenote, the sony clie came with a universal remote program, i caused much chaos in my local video stores by shutting down their video wall while browsing.
Posted on Nov 16, 2007
SOURCE: channels keep changing
Make sure there is no other remote control working simultaneously or with a key pressed constantly by mistake. In my case i found the air conditioning remote control with one key being pressed by my furniture next to my bed, it was causing that erratic behavior. As soon i realized, i stopped that remote control and problem solved. I hope this works.
Posted on Nov 27, 2007
SOURCE: 42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
Posted on Jan 11, 2009
SOURCE: Scanning dtv channels
go to menu setup and do the full system reset setup option... Then before you scan for channels make sure it is set to cable... This fixed the problem for me.
Posted on Feb 12, 2009
  • 718 Answers
SOURCE: Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Posted on Mar 16, 2009
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
It is not picking up the channels , i have cable and no channnels are working at all,not even the local channels.when am changing the channel it starts at DTV then TV,then CADTV,and then CATV
Sounds like you may have a stuck button on the tv causing uncontrolled selection or the Main bd is bad. Try hooking up a different source such as a DVD player to the same input on the tv. If the tv works ok you might have a bad cable Box as well.
Jul 08, 2009 | Televison & Video
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
Vizio L32 32 in. LCD HDTV Logo
116 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
