Question about Carrier 38BRC048 Air Conditioner
Condenser does not kick on - Carrier 38BRC048 Air Conditioner
    Problem Solver:
  • 6 Answers
Relay on the control board is shot. Replace relay or entire board.
Posted on Jun 12, 2010
The fan on my GT345 chest freezer runs constantly. Is this correct ?
Depends are you referring to the condenser fan or the evaporation fan? If it's the condenser fan you may have an issue with debris in the condenser coil not letting enough air flow to cool down so it will stay on to keep from burning up compressor.If it's inside the evaporator coil then it may be low on refrigerant possibly freezing up the evap coil making it run then kick into defrost run kick into defrost etc... hope this helps
Aug 12, 2014 | Freezers
When the condenser kicks on it will makes a buzzing/whing sound for the time it is on. When the condenser kicks off the sounds stops. It kicks on and off every couple of minutes.
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 11, 2011 | Frigidaire FRS26RLECS Side by Side...
Condenser want start or hum getting power to contactor
Check for 24v power to the contactor coil...Is the contactor pulling in???
If you are getting 24v to the condenser but the coil is not pulling in then there is a safety control kicked in the condenser...if no 24v to condenser then it is probably a t-stat problem...
heatman101
Aug 30, 2011 | Goodman CLQ36AR49 Air Conditioner
Our window unit will cool for 30 seconds then kicks off. the compressor also doesnt kick off... when it is cooling the air is ice cold. where is the condensor on this unit
The condenser in a window AC is a that winding pipe that's covered with aluminum fins on the outside. When the refrigerant EVAPORATES, it draws heat from your room. When it CONDENSES, it releases heat to the outside. It's basically a heat pump.
Jul 19, 2011 | Heating & Cooling
My GE portable a/c will cool when I first turn it on. The compressor kicks on and it cools fine, but after it runs a few minutes it kicks off and never cools again. The fan just runs. It does not appear...
I would say that if it starts cooling when it's turned on, then it has freon in it. Sounds more like it's kicking off on high head pressure, meaning the condenser is not getting cooled, head pressure builds up then a safety limit switch shuts it down to save the compressor from burning out.. Is there a condenser fan maybe not operating? or are the condenser coils clogged up with dirt?
Jul 15, 2010 | General Electric APE08AK Portable Air...
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
My 1997 Honda Accord 4cyl. condenser fan began to run continuously (even after engine was shut off) after cycling the A/C temp. selector from hot to cold. I disconnect the condenser fan to avoid draining...
Sounds like the AC relay/switch is sticking on sometimes. Locate and swap this relay. Look at your fuse box lids for location or search online for the exact location. You also might have a leak in the ac lines or the AC condenser clutch is not engaging to kick the ac on. You should feel a slight power loss or hear a slight stutter in the engine when pressing your AC switch. This means everything kicked on. It's a millisecond before the ECU realizes this and kicks up the idle to compensate.
Sep 23, 2009 | 1997 Honda Accord
Vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
May 30, 2009 | Sub-Zero 650 / O Bottom Freezer...
Carrier 38BRC048 Air Conditioner Logo
125 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
