Question about Sony Playstation 3 (PS3) Console
How to reset an ps3 controller ? ive done da resset button thing but it dont work
  • Sony Master
  • 6,993 Answers
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
Good luck.
Posted on May 30, 2010
Gioteck vx1 wireless controller will not pair up to my ps3
This works: Turn ps3 on. Plug the controller into the usb cable and into ps3. Then plug the dongle into other usb port. After a short time the dongle will flash quickly (this means it's in pairing mode - when the dongle flashes slowly it's too late). Press the PS/Home button as soon as you see the dongle fast flashing. All the LED's on the controller will begin to flash and after a short time one (or two) will remain solid. Immediately disconnect the charging usb lead from the controller and again the LED's will flash, push the PS/Home button again and after a short time one or two will remain solid. The controller should now be working. If the controller fails to respond repeat this process but make sure that you disconnect the dongle and reinsert (so you can see the fast flashing lights and try again).
Jan 04, 2012 | Video Game Consoles & Games
My ps3 has no video but the sound works i can here the menu when scrolling through it ive tried the reset and it lets me pick my settings but then when its done it still has no video any help is welcome...
Try to reset the video settings on the PS3 and also make sure the cables are all attached and that you have the TV on the correct input source.
Turn the PS3 off so the red light is on. Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
That should have reset the video settings so you will be able to set the video settings again on the other TV and access the PS3 menu to set it up.
If there is anything else please post back.
Regards.
Jan 07, 2011 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: i had a power cut whilst playing ps3 , now it wont...
First thing to try is a video reset.
While the PS3 if off (red light solid) hold down the power button until you hear the SECOND beep, quickly release.
Let me know if this works, otherwise we'll try step 2.
May 16, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont broadcast cast right.
Try holding down the power button for 2 beeps. This will reset the PS3 video to standard mode.
Mar 24, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont power all the way up
if you have moved your ps3 to a different tv or something, the video setting can get messed up, thus having to reset the video settings. here are a few steps to do so.
1. put your finger on the reset button and wait until the ps3 is in standby. (Keep holding your finger on it, don't let go)
2. turn off the ps3 completely by switching off the power switch (make sure your still holding your finger on the reset button)
3. turn your ps3 back on (while still holding the reset button) and you will hear a beep. keep holding the reset button until you hear a second beep. let go of the reset button as soon as you hear the second beep
this should reset the video of your ps3. ive done this to my ps3 before because when i was installing linux i almost screwed up my ps3. when i turned on my ps3 no picture or sound would appear. so i called sony and this is what they told me to do and it worked.
Jul 09, 2009 | Sony PS3 40GB Best Sellers Bundle Console
My Ps3 contollers are not working. I tried to reset the contollers with the little button in the bakc. But it still doesnt work. I tried connectin da USB cable to the Ps3 and it wont work. What do i do???
On the flip side of your controller, to the RIGHT of the screwhole, there's a pin hole. This is actually a reset button. Using a pencil, or similar sharp object, give that a gentle push. This will turn it off. Press the PS button on the regular side once to get it turned back on. See if this solves your issue. If not, message me back under this heading and I'll see what else can be done, ok? I'll also do a little research on this issue cause it is fairly common. Good luck, bro!
May 25, 2009 | Sony Playstation 3 (PS3) Console
It POWERS ON BUT HAS NO PICTURE,
Okay, I am now going through all the unsolved problems for which previously I had the same problems and now posting our solution. First, if you have no pic due to swiching of the cables (ie, cable av, hdmi) WHENEVER you switch your cable output, the ps3 also switches it's output. Make sure when there is no picture due to this problem to turn off the game console, then turn on, hold down the power button for approx. 5 SECs, there will be a BEEP. Let go of power button, the ps3 has then switched back to the output it is currently plugged in and will work. (ALSO sometimes you have to have ONLY the ps3 and tv hooked up) Hope this helped. I know how stressful this can be!
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
