Question about Microsoft Xbox 360 Elite Console
E 74 - Microsoft Xbox 360 Elite Console
    President:
  • 1,469 Answers
When you get the dreaded Disk Read Error, it normally occurs for one of two reasons. Either dust has built up on the lens of the laser mechanism, or the operating voltage of the laser has drifted off slightly due to heat and age. Of course, occasionally there are actual failures of components, which cause this, but these are the main two reasons.
Tools required by this guide are (not all are required for all parts however):
1) A normal sizes star (Phillips) screwdriver. 2) A very small Phillips screwdriver. 3) A small, flat screwdriver. 4) Some isopropanol alcohol (IPA) 5) A few cotton buds 6) A little mechanical grease. (I’ve used Vaseline before) 7
Cleaning the laser lens
1) Remove any CDs from the unit and unplug all leads and memory cards. Turn the unit upside down and use the small, flat screwdriver to pop out all the little plastic and rubber screw covers.
2) Take your normal sized Phillips screwdriver and unscrew all the screws
3) Try to write down where each part comes from (including the screws as they have to be returned to the same location at the end. Stick them in a tub to keep them safe.
4) Turn the unit back up the right way, holding it all together. Place on the work surface and gently ease the case open. You may have to tilt the lid slightly towards the front, and slide out to avoid the cd tray. BE CAREFUL not to damage the eject/power button ribbon cable, as these are very fragile.
Gently lift off the lens casing and you will see the slide tray underneath.
Gently pull the tray away from the rest of the unit by carefully sliding it all the way to the front until it has cleared the lip on the right of the tray. Look for any damage or wear, as this could be a cause of the unit malfunctioning. If you have compressed air give a few little squirts to any places, where you see dust, but you must be careful not to damage the laser lens.
Take a cotton bud and careful place some of the alcohol on it (but not so much that it is dripping everywhere). This alcohol is the same (or similar) to the small bottle of alcohol which is in audio and video cassette cleaning kits. This is probably the best way to locate a source. Locate the lens (the circular glass part) and very gently rub the cotton bud around the lens in circular motions for about 30 seconds, being very gentle. Once done, flip the cotton bud over and dry the lens with the other end for about 10 seconds.
The laser part slides on rods to reach different rings of the cd. These can become clogged up with dirt and dust, making movement difficult. So, take a clean cotton bud and clean the slide rods thoroughly, making sure you get to all parts and give a good clean.
The spin rod controls the movement of the laser and is greased to allow smooth frictionless movement. Clean the surface of the spin rod. If you have some grease to replace with then remove all the dusty grease (or as much as you can) and then apply some fresh grease. If you have no grease to replace with then just remove any excess dirt but try to leave a little grease, as it is required for the mechanism to work.
Clean the little cogs too so that all possible avenues are covered.
You have now completed the cleaning process. This often cures read errors and should always be attempted first. Reverse the dismantling process and put the machine back together, making sure you DON’T TRAP the eject / power button ribbon cable, as this can cause serious problems for you if it happens. Power on the unit and try to load both a CD and a DVD game. If all works fine then CONGRATULATIONS on completing the guide successfully. If however there is no change then you should proceed to the next step - Adjusting the Disk Mechanism.
This will then require a skilled personnel to handle this .
Take care.
Posted on May 30, 2010
Winchester model 74 serial # 11901, what year was that gun made
My Internet at work doesn't like 'weapons'. These links will help you find the date.
Model 74 - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=winxx74.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 74: Covering numbers: 30890 - 406574. Please enter a serial number and click the submit ...
oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. Lever Action Rifles. Henry Rifles · Model 1866 · Model 1873 · Model 1876 ... Model 1892 · Model 1894 (Mod 94)
Winchester Model 74 .22 sr dating question ' The Firearms Forum
www.thefirearmsforum.com/.../winchester-model-74-22-sr-dating-questi... Sep 8, 2010 - I have a Winchester model 74 .22 short rifle and am having a hard time looking up the serial number to date it. The serial is 22736. Winchester Model 74 22 Semi-auto Rifle 28 Mar 2014 Winchester Model 74 .22 Long Bore 6 Oct 2007 Winchester Model 74 3 Mar 2007 More results from www.thefirearmsforum.com
Winchester Model 74 Value And Date ' Gun Values Board
www.gunvaluesboard.com/winchester-model-74-value-and-date-158857... Nov 17, 2011 - Winchester model 74 value and date ... Posted on Winchester ... This is a barrel date of manufacture that is helpful in approximating the date of manufacture of ... Winchester 74 Serial Number 6694 Value 1 Jan 2016 1941 Winchester 22 LR Model 74 Serial Number 106978 15 Jul 2012 Winchester Model 74 22 Short 3 Jan 2011 More results from www.gunvaluesboard.com
Jan 22, 2016 | Winchester Optics
Need a manual for paragon timer EC 74/120D
Try Googling (paragon)(EC 74/120D)(manual) without parens.
Nov 11, 2013 | Paragon 4001-00 24-hr Timer Control 120v...
Find the median for 74
The median of one number is that number, so the median of 74 is 74.
Aug 13, 2013 | Computers & Internet
Tv turns off all by its self
temp_M2AU87XURE-F01TFFv2fbA==_0.tmp Header Data : 2e 52 4d 46 00 00 00 12 00 01 00 00 00 00 00 00 .RMF............ 00 06 50 52 4f 50 00 00 00 32 00 00 00 00 3e 80 ..PROP...2....>. 00 00 3e 80 00 00 01 40 00 00 01 40 00 00 00 ba ..>....@...@.... 00 00 74 40 00 00 03 c0 00 00 f3 71 00 00 02 27 ..t@.......q...' 00 02 00 09 43 4f 4e 54 00 00 00 3e 00 00 00 0b ....CONT...>.... 54 56 20 42 39 32 20 6c 69 76 65 00 07 42 39 32 TV B92 live..B92 2e 6e 65 74 00 1a 62 39 32 2e 6e 65 74 20 2d 20 .net..b92.net - 69 6e 74 65 72 6e 65 74 2e 62 39 32 2e 6e 65 74 internet.b92.net 00 00 4d 44 50 52 00 00 01 09 00 00 00 01 ff ff ..MDPR.......... ff ff ff ff ff ff 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 10 6c 6f 67 69 ............logi 63 61 6c 2d 66 69 6c 65 69 6e 66 6f 00 00 00 cb cal-fileinfo.... 00 00 00 cb 00 00 00 00 00 00 00 06 00 00 00 1e ................ 00 00 0d 49 73 49 6e 74 65 72 6c 65 61 76 65 64 ...IsInterleaved 00 00 00 00 00 04 00 00 00 01 00 00 00 1f 00 00 ................ 0e 52 54 50 50 61 79 6c 6f 61 64 54 79 70 65 00 .RTPPayloadType. 00 00 00 00 04 00 00 00 65 00 00 00 21 00 00 10 ........e...!... 53 61 6d 70 6c 65 73 50 65 72 53 65 63 6f 6e 64 SamplesPerSecond 00 00 00 00 00 04 00 00 03 e8 00 00 00 24 00 00 .............$.. 13 53 65 65 6b 47 72 65 61 74 65 72 4f 6e 53 77 .SeekGreaterOnSw 69 74 63 68 00 00 00 00 00 04 00 00 00 00 00 00 itch............ 00 1f 00 00 11 50 61 79 6c 6f 61 64 50 61 72 61 .....PayloadPara 6d 65 74 65 72 73 00 00 00 02 00 01 00 00 00 00 meters.......... 1e 00 00 08 53 65 65 6b 54 79 70 65 00 00 00 02 ....SeekType.... 00 09 4b 65 79 46 72 61 6d 65 00 4d 44 50 52 00 ..KeyFrame.MDPR. 00 00 9c 00 00 00 00 00 00 3e 80 00 00 3e 80 00 .........>...>.. 00 01 40 00 00 01 40 00 00 00 00 00 00 03 c0 00 ..@...@......... 00 74 40 0c 41 75 64 69 6f 20 53 74 72 65 61 6d .t@.Audio Stream 14 61 75 64 69 6f 2f 78 2d 70 6e 2d 72 65 61 6c .audio/x-pn-real 61 75 64 69 6f 00 00 00 4e 2e 72 61 fd 00 05 00 audio...N.ra.... 00 2e 72 61 35 00 00 00 10 00 05 00 00 00 3e 00 ..ra5.........>. 03 00 00 01 40 00 00 00 00 00 01 d4 c0 00 00 00 ....@...........
Feb 26, 2010 | RCA Televison & Video
Drills but dont hammer te 74
Hilti no longer carries parts for the 74. However most of the TE75 parts will interchange with the 74
Jan 31, 2010 | Hilti Drills
How to replace headlight on a 2003 Chevy Tracker
There are two black plastic clips behind the the air filter, remove them and release the whole assembly to access the lights.
If you still get in troubles, have it replaced at a petrol station, they will help you in fitting the bulb, and it won't be expensive.
Here follows
2003 Chevrolet Tracker Light Bulb Size Chart
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 1157A
Front Turn Signal Light Bulb Size: 1157A
Rear Turn Signal Light Bulb Size: 921
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 168 Or 921
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 74
Step/Courtesy Light Bulb Size: 168
Trunk/Cargo Area Light Bulb Size: 168
Instrument-General Light Bulb Size: 158 or 74
Check Engine Indicator Light Bulb Size: 74
Hi-Beam Indicator Light Bulb Size: 74
Seat Belt Indicator Light Bulb Size: 74
Brake Warning Light Bulb Size: 74
Automatic Transmission Indicator Light Bulb Size: 74
Directional Signal Indicator Light Bulb Size: 74
Oct 02, 2008 | 2003 Chevrolet Tracker
Console
error code 74 is
74: AV cable Error - There is a problem with the AV cable, try using a different AV cable.
hope this solves your problem
Maxicube
Feb 10, 2008 | Microsoft Xbox 360 Console
Lost manual
instructions for programming the Midland 74-210 are here:
http://www.srh.noaa.gov/mob/nwrhelp.shtml#Midland74210
Sep 03, 2007 | Midland 74-210 Radio
Microsoft Xbox 360 Elite Console Logo
73 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
