Question about Craftsman Convertible 25cc. Gas Line Trimmer
How to replace clutch on weedeater
Can not figure out to remove clutch
  • 279 Answers
The metal cover over the clutch is held on with a screw in the center. It takes a #15 or 20 TORX screwdriver. Once that is off you will see which way to take off the clutch. Good luck...Lee
Posted on May 30, 2010
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Pull rope brok on my weedeater i can"t get the clutch cover off to fix it
The clutch cover is usually held with a number of screws around the outside edge, you then need to remove the clutch, as the cover cannot come off with this in the way, there is normally a 9/16 or a 1/2 nut holding the clutch on, there will then be a large washer, then a tube through the clutch houseing as the clutch nut also holds the flywheel on.
Feb 16, 2011 | Garden
WEEDEATER GHT 180 PULL CORD CAME OUT. I HAVE EVERYTHING TAKEN APART BUT CANT GET THE CLUTCH OFF. i HAVE REMOVED THE SPRINGS ON THE CLUTCH PLATE AND TWO HALF MOON PLATES. nOW WHAT?
i removed the clutch by sticking a screwdriver into the fly wheel and used a big cresent to twist it off . IT HAS A 8X1.0 MM THREAD WHICH IS A VERY COMON SIZE, lol capz. im only 13 nd ive got two of these motors whice i hav modifyed and put in a 48" boat. excuse me 4 the bad typin
Oct 18, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
I need to remove the clutch assembly from the shaft. Is there a special tool or technique I need to know about?
You will need to remove the bolt from the centre of the centrafugal clutch and remove it from the shaft with a flywheel puller. Good luck!
Aug 11, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
The pull string coil came loose cant figure out how to get the piece that connects to the shaft off on the ryobi ss30 weedeater
There is a cover that you loosen you pull back the handle then youll see a clamp I think its 5/16 loosen it will move but there is a thottle cable you have to loose off the thottle on thr carberator then it will slide off ,if it is a clutch ,the clutch has to be removed by the way of the the arrow then you can get to the rewind
Nov 04, 2009 | Ryobi Garden
Need to replace rope on a Poulan ppb 350 weedeater.
Is this a trimmer? Not aware of a tiller by this model number. if it is the trimmer the most likely problem you will encounter is removing the clutch drum to get the clutch off the crankshaft. There is a screw inside the tail if the drum.
Sep 14, 2009 | Garden
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Craftsman Convertible 25cc. Gas Line Trimmer Logo
798 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
