Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Clutch adjustment I have a Husqvarna GTH 2448t riding tractor & the clutch pedal will not fully pull back. So the tractor will not move until you pull the pedal back with the top of your foot. Any suggestions,
    Brigadier General:
  • 3,911 Answers
I had the exact same problem on my Husq 2148 which arose just after a new drive belt was put on. There is a cage around the front, engine, pulley which keeps the belt from flying off I guess. After staring at the belt for a long, 2 beers, time I discovered the repair guy had put the belt inside the cage on one side, where it is supposed to be, but outside the cage on the other side. This caused the problem you described and it ran much better in reverse than forward. If your problem arose after a belt change, I would start looking there, if not then I would check the 2 springs which keep back tension on the pedal. It took me 3 more beers to get the thing put on right.
Posted on Jun 01, 2010
Husqvarna YTH2348 when clutch pedal is released, something grinds below and makes a lot of noise, but tractor does move.
Not sure what is going on here, these machines do not have a clutch as such, it will be a idler pulley that is pulled onto the back of the belt to tention it thus taking the drive to the hydro unit, so it may be a simple idler pulley replacment, or slave pulley replacement, with the hydro in neutral have somebody sit in the seat and work the pedal whilst you look under neath and watch what is happening.
Jul 26, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have inherited a ride-on tractor, Husqvarna LT19538, without an operators manual. Can you please tell me how to start it?
Make sure you have gas, oil, and a fully charged battery.
Sitting on seat, push the clutch/brake pedal down fully, make sure the mower PTO is in the "off position". Push throttle control to choke, or pull the choke handle, whichever set up you have, and then turn the key.
Sep 20, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
H uskavarna mod.960 250002101. I don't have fire
Parts Manual:
http://www.searspartsdirect.com/partsdirect/part-model/Husqvarna-Parts/Riding-mower-tractor-Parts/Model-96025000200/3199/1509200?searchedModel=960.250&blt=
Wiring diagram: (zoom to 200%)
http://c.searspartsdirect.com/lis_png/PLDM/1006648P-00012.png
Jumper white to white on the PTO clutch wires and see if it will turn over.
Result = No check to make sure the clutch / brake pedal switch is being made when you depress the brake.
Next install the Seat switch jumpers black to black and gray to gray for TESTING only and attempt a start.
Last... use a longer jumper and connect White wire of PTO to the solenoid small ( + ) terminal and try a start. If it starts here the clutch / brake switch is bad.
You can do this.. it is not hard. Just a matter of sorting out which switch is not working.
Something to try before installing jumpers... Bounce on the seat pretty hard several times and cycle the clutch / brake pedal through full stroke. I.e fully depressed and then pull it all the way to the top for 5 or 6 cycles. Then attempt start.
Feel free to post any comments or questions anytime. I will respond.
Thanks for choosing FixYa,
Kelly
May 14, 2011 | Husqvarna 22 Hp 46" Deck Yard Tractor
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna gth 2448t 48'' 24 hp riding mower 2007
YA IT SOUNDS LIKE YOUR SEAT SWICH IS BAD THATS THE MOST COMON THING I SEE A LOT OF LET ME KNOW IF THIS HELPS YOU
Oct 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Clutch/brake adjustment
adjust clutch
Jul 06, 2009 | Garden
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
418 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
