Question about Whirlpool GU2700XTSS / GU2700XTSY Built-in Dishwasher
Removal of filter module
Broken glass pieces in bottom of unit
    President:
  • Whirlpool Master
  • 2,651 Answers
The wash spray arm unscrews, then there are 5 torx 20 screws removing the top filter plate, under there is anohter 2 torx 15 screws allowing you acess to the chopper assy
Posted on Apr 09, 2008
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Will not drain
Hello Keith, thank you for allowing me to assist you!
Often when a dishwasher does not drain, it is because the drain hose may be clogged or you have a faulty drain pump. First, I recommend cleaning the glass trap that is located in the center of the unit designed to collect pieces of broken straws, bones, glass, etc. The filter can be removed for cleaning by simply grasping the handle and lift it out. Once you empty the filter, you may wash it with warm soapy water and allow it dry. Then place filter back. However, if you continue to have water left in the sump and the dishwasher is making a grinding noise, then it is recommended that the drain motor be diagnosed. You can locate a certified technician directly through the manufacturer website or in your local directory.
Jan 09, 2014 | Frigidaire Dishwashers
Our 2 year old Miele dishwasher (G1182/G2182) makes a strange popping/grinding glass noise when draining. We used 1 bottle of Finish Intensive care & clean with no improvement. Any suggestions?
there is a piece of debris in the drain pump. remove the triple filter from the bottom ( the one you are supposed to clean every week to keep debris out of the drain pump) under that filter and to the left hand side you will see the non return valve. squeeze the tab and pull the non return valve out. remove the broken glass or whatever is stuck in the drain pump impeller. replace the non return valve. replace the filter. if you need a picture go to mieleusa.com, and search for your owners manual. it has step by step tutorials on how to free an obstruction from your drain pump.
May 27, 2012 | Miele Dishwashers
How do you remove the screen frame to remove broken glass? Can the glass be replaced with a piece of plexi glass?
hello am rico, no you cant, unscrew all the screws from the back and bottom front. should be able to open it. if you need more help let me know. 602-810-7149
Jan 07, 2011 | Sony KP-51HW40 51" Rear Projection...
Making grinding noise when started
Sound like you have a bit of broken glass or a fruit seed caught in the drain pump. Remove the filter and in the sump there should be a non return valve. Remove this and have a look for any foreign particles. Start the unit up without the filter and non return valve in or the bottom basket. Allow to run for about 10 sec. then open the door and hopefully the unit has thown out the noisey culprit. Have good look around the base and sump of the unit. Glass is also hard to spot as well. hope this helps.
Jan 24, 2010 | Maytag PDB3600A Built-in Dishwasher
How do I clear out a piece of broken glass? It
first try removing bottom spray arm and run sometimes you can blow the obstruction out if not switch of power lean or lay the machine in in a position where you can access the wash motor remove carefully noting what you have done for re installation remove glass and re fit test for leaks hope this helps
Nov 13, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Bosch dishwasher wont drain. At end of cycle is full of cloudy water.
It is possible if you have broken a glass recently that the piece of glass has made its way to the drain pump impeller. You need to remove bottom basket. Remove the filter strainer clamp by rotating CCW. There may be another round filter under the strainer (depending on model). Then with a torque screwdriver remove one screw which holds the plastic pump cover on. Remove the pump cover and pay close attention to the pump impeller. Does it rotate by finger movement? If not it could be jamed with a piece of broken glass. You must remove any obstruction to allow the impeller to turn. I usually force a paper towel piece (half piece while rotating the impeller by finger to allow the paper towel to bring up any obstruction below the impeller) Reassemble the cover and filters carefully and make sure the final strainer clamp aligns correctly with its marks. This insures nothing will make its way to the impeller in future.
Regards Sam
Jun 15, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My oven door shattered. i bought the glass and the outer trim. i need help installing it
This job is best done by two people, one to hold the glass in place, and the other to operate the screwdriver and position the handle and trim pieces.
The glass is held in place by the handle assembly at the top and a metal track at the bottom.  You remove the glass by removing the handle. Open the door part way until you have access to the back of the door.  The door handle is held in place by two screws on the back (the oven side).  Remove the screws, taking care to hold the handle in place.  Be sure to brace the glass, then slowly move the handle away from the door frame.  Remove the glass.  The side trim pieces will probably fall away from the door frame, although they will probably not fall all the way out.  My advice is to carefully remove them.  Be careful; they have tabs on the bottom edge that hold them in the door frame and these tabs are easily broken.  If yours are still in one piece you might just reuse them.
Remove the old glass panel and clear the bottom track of any debris.  Put the new glass panel in, beginning with the bottom track.  Set the oven handle on the top edge of the glass panel; there are tracks on the back of the handle assembly the top edge of the glass fits into.  Bring the handle toward the door frame, taking care not to let the glass panel slip out of the tracks.   The door handle has two collars that go through holes in the door frame.  Once you've got the collars through these holes, you can put the two screws back in that secure the handle to the door.
Take one of the side trim pieces.  Each trim piece has a narrow edge and a wide edge (like a capital "L"), The narrow edge faces the front and the wide edge faces the side of the door.  Each piece has a corner edge with a little tab sticking out.  These face down.  The opposite end of the trim piece has recessed edges. These slide under the edge of the door handle.  You want to insert this end first, then work your way along the length of the trim piece pushing the narrow edge between the door frame and the glass panel.
Here's the tricky part.  To get the bottom in, the best thing to do is to open (or better yet remove altogether) the drawer beneath the oven to gain access to the screws that hold the bottom track of the glass panel to the door.  Loosen the screw that holds the track in on the same side as the trim piece you're working on; the screws are on the bottom of the track about 1 inch in from the edge. Loosen the screw slightly and pull down on that edge of the trim as you push the trim piece in behind the glass.  Repeat until the trim piece tab slips through the hole for it on the track.  Tighten the screw back in place.
Repeat this process for the other trim piece. If you're patient and gentle, it shouldn't be too difficult.  I just did this myself today (2/7/09).
Good luck.
Jan 24, 2009 | Kitchen Ranges
Broken glass at bottom of dishwasher
There should be torx screws or 1/4 inch screws holding the filter down to the bottom , you should know when you get there because you cant go any further. good luck.
Dec 30, 2008 | Frigidaire Dishwashers
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
Open Questions:
See all Whirlpool GU2700XTSS / GU2700XTSY Built-in Questions
Whirlpool GU2700XTSS / GU2700XTSY Built-in Dishwasher Logo
266 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
