Question about Acer Aspire 5050-3371 Notebook
Acer 5050-5554, computer will start but blank screen. Try hard restart but no go. Tried to flash the bios but nothing. Anyother recommendations
    Guru:
  • Acer Master
  • 1,705 Answers
Could be a dead screen or bad screen connection.
Try connecting it to a slave screen using the VGA connector and "Fn" keys. If that doesn't work you graphics card/chip is at fault.
If it does work its a screen problem, you could remove all power sources and try to get at the screen connectors. Usually under a panel between the keyboard and screen hinges. Be careful, they're usually clipped and screwed in, hard to move and easy to break.
Look for your screen and inverter connectors, ribbon connectors with a wide narrow plug, make sure they're home and good. If not you've possibly found the fault.
If they are home and good, you've probably got a screen or inverter fault. Time to get a tech.
Posted on May 30, 2010
My Acer laptop will not boot up.
You may have a corrupted video driver due to an update. For some Acers, press and hold F10 when starting the computer. Two beeps will mean that the bios settings have been restored and the machine may boot correctly. If you can enter the BIOS via F2, F1, F10, ESC or DEL, then find the area for display and change it to low resolution then save and restart your computer. Once running, you will need to uninstall the current video driver and have the computer install a new one.
Mar 18, 2017 | Acer Aspire 5736z 4460 Laptop
Blank screen
  • With the computer on, use a flash light to inspect the screen. If you can see a very faint image then either the inverter board is bad or back light. Usually its the inverter.
  • If you get nothing, plug an external monitor and toggle the display to it. If you get output then your screen is bad or possibly a loose video cable.
  • If you get nothing, power off, pull battery pull all memory out. Power on computer. If you get BIOS and a no memory error, one of your memory modules is bad.
  • Still nothing, then the motherboard is bad.
Jan 29, 2013 | Acer Veriton Z290G 185 320GB
I have an acer laptop. I downloaded service pack 2 and service pack 1. The computer was working well until the service pack 1 was installed. When it restarted my computer, it went to a black screen that...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
then defragment your hard drive also
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
dont forget to vote
Feb 04, 2011 | Acer Aspire™ T180 PC Desktop
I was trying to update the Bios when my pocket pc went to a screen that has the word "Serial" at the top, a hp blue logo in the center with the word invent underneath it and at the bottom it has a v1.08. I...
Not a problem it happens just go to hp.com download the bios driver and use it on windows xp it will not work with anyother windows and run it with your ipaq connected to the pc. This will reinstall the complete bios software and bring it back to factory.
Aug 10, 2010 | HP iPAQ H2200 Pocket PC
My Acer Aspire one D250-1938 shows a blank screen only. Maybe it somehow stuck in hibernation mode. Have forced shutdown and restarted, tried F5, F6, F7, but still no screen. Any suggestions?
Try remove the battery, let it for 30 minutes without it, then plug it again the battery, then turn it on.
If still won't work, remove again the battery, wait till 30 minutes, the plug the charger, don't use the battery yet, then turn it on.If it works, you can plug in the battery again.
Feb 26, 2010 | Acer Aspire One PC Notebook
Acer aspire 5535 hibernation blank screen stuck
it might be your harddisk you should check it first it may not be loading your o/s or unbootable partition
Sep 08, 2009 | Acer Aspire 5535-5050 Notebook
I was trying to go through recovery thinking I could get more speed on laptop and I messed comp. up. Only get a blank black screen. tried powering down, rebooting, still can't get on. Help!! i was trying...
Flashing the Bios is a LAST DITCH effort to resolve Hardware issues. You should NEVER flash the bios unless you are absolutely certain it's the correct bios for your computer, also NEVER flash bios from within windows..
There may however be a solution for you, Acer laptop computers with the Pheonix BIOS sometimes has a " flashback" feature, allowing you to revert to your original Bios..
You will need to contact Acer to get a Crisis Bios recovery disk from them. Or ask for further information on how exactly to recover from a bad bios flash.
May 30, 2009 | Acer Aspire™ T180 PC Desktop
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Power ON/ nothing on screen-
enter the bios setup, if you can boot the computer/laptop. Usually F2 on bootup, it will say entering Setup.
Then scroll through the pages to see if your hard-drive is recognised by the system.
Mike @ Compurepair.
Feb 24, 2008 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5050-3371 Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
