Wireless network, Roadrunner broadband, XP Home Usually runs at 54Mbps, Excellent signal strength. But, even with Excellent signal, sometimes drops to 36 Mbps, 24 Mbps, even 0 Mbps. Why would it do this?
  • efsunderl771 May 30, 2010
    This answer doesn't tell me anything about what causes the problem. It only started recently, so I think something must have changed.
  • 560 Answers
54mbps is the speed of your wireless router and not your broadband. What is the brand and model of your wireless router/access point?
Please check for possible interference between your computer and wireless router.
Posted on May 30, 2010
  • 1 more comment
    Thanks for the response.
    Netgear WGR614
    and yes, it says it's 54 Mbps.
  • Liza Halbrook
    Liza Halbrook May 30, 2010
    1. Update your computer to SP2 or higher.
    2. If you have other wireless device within the Netgear wireless range, make sure that you are using different RF channels on each device. Turn off all other wireless devices then turn them on one by one and see which is causing the interference. You may also test RF channels 1-6 and 11 and see what channel it connects without dropping.
    3. Download and update your firmware.http://kb.netgear.com/app/products/famil...
    thanks for this. I'll take some time to try it out and get back if I have more questions
    Guru:
  • 528 Answers
Hi. Since you are using wireless network, the reading that you are getting is somewhat standard. As we all know, data travels much more faster and stable in a regular copper line than a wireless signal. Wireless connection is for backup use only incase you have problem with your wired connection. You can stick to wireless but thats the downside of using the wireless technology.
  • Archie Cruz
    Archie Cruz May 30, 2010
    I see. Did you install application/software to your computer or any hardware modification? If none, then all you need to do is to restore the computer back to the date you remember that the computer is woring fine. You can use system restore.
    Please folow this procedure:
    Click start menu
    Click All programs
    Click accessories
    Click system tools
    Click system restore
    Choose a date where you want to restore the computer (make sure that the date is where your computer works fine)
    Restore the computer to that date
    If same issue will happen. I suggest you call your local internet service provider might be there is a service interruption in your area that causes this issue.
After 3 years with the Linksys wireless G broadband router and excellent strength, the last 3 days my wireless router is producing a very low signal....why?
Sometimes, new interference from devices unknown to you cause the problem. Additions of a new microwave, cell phone or even faulty wiring in the house can output electrical interference.
But it is not uncommon for the Linksys routers radio to fail as well.
Consider replacing it with a newer Linksys router that will be compatible with docsis3 speeds and above.
Jun 17, 2011 | Linksys Wireless-G Broadband Router
Unable to stream novie sites with my linksys wireless-g router
Check the connection (signal) strength of your wireless connection in the status area of the task bar in Windows. Also, hovering the mouse over the wireless connection should reveal the connection speed. 54mbps is the highest you can expect on a wireless connection, which is generally OK for streaming video..Any less of a signal strength/connect speed will likely not be adequate for streaming video.
A poor signal strength is usually because of too much distance or too many walls between the router and the computer.
Hope that's helpful.
Jan 15, 2011 | Linksys Wireless-G WRT54G Router
TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC): signal strength 85% green but tx rate 11 instead o...
Im sorry but you will never get 54 on your card toughs are theoretical maximum speeds and I have never seen a system actually achieve them the actual speeds received by wireless devices are actually much lower and 11 is a normal speed wile running over wireless. Im sure this isnt what you wanted to here and I am sorry but it pretty much comes down to manufactures lieing by telling you it goes to speeds that can never be reached.
I hope this helped.
Thank you,
Norse
May 16, 2010 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
Cannot connect to the router
Right click the network icon in the system tray. Click "repair."
If that doesn't work.Power off netbook, router, modem...
Turn on router. Then Modem. Then netbook in that order waiting 1 minute interval between each.
Everything should be functioning ok.
Dec 21, 2009 | Linksys WRT54G2 Wireless Router
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Dell XPS Desktop with wireless adapter will not communicate with the Internet. Signal strength excellent, no communication. Laptop with wireless works fine in same physical location. Linksys unable to...
Yes, XP Pro SP2 tends to give a network or browsing issue. Check proxy server settings as well or Apply the DNS staticly to the Wireless Network Adapter's TCP/IP properties and see what happens???
Jul 27, 2009 | Computers & Internet
WIRELESS NETWORKING
There are several problems reported that may cause disconnection. First is the hiding of the SSID (wireless network name) and enabling WEP or WPA encryption. The recommended solution for that is to unhide the SSID in the router configuration.
Second is that there are more and more wireless devices and occasionally interference occurs on a single channel (even from non computer devices like wireless phones. As routers are often set to channel 6 you may be competing for radio communications with your neighbors. The recommendation is to switch the router to either channel 1 or 11. If your first choice does not work try the other.
Dec 24, 2007 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
