Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
What is the chance of getting a good used Poulan 20 hp 42 inch cut? I am buying a used one for 300. One of the spindles is broken. Is this a good deal? Any known issues with these? Its not a pro.
    Problem Solver:
  • 15 Answers
Checck price on spindle, as they may run a high price
Posted on May 31, 2010
Put new belt on 42 inch poulan pro, now one side cuts lower than other
Spindle is most likely wore out allowing on blade to drop down lower than the other.( most likely )?? 25+ years small engine mechanic as well as motorsports.(solution buy mew bearings replace or sometimes cheaper to just replace whole spinde with bearings already in it. Hope this helped.Ofcorse could b bent blades ect but most likely the bearings have allowed blade to drop down.
Jun 30, 2012 | Garden
Poulan Pro 300 42" cut
Likely a valve or check valve is frozen. Refer to your manual showing hydraulic circuits and it will probably be obvious where a blockage that prevents ANY oil flow to the drive motors could occur.
Jun 30, 2011 | Garden
Have and older style Poulan rider mower with a 14.5 hp and 42 inch cut. Replaced Battery, starter selenoid, and ignition switch. Now the 30 amp fuse keeps blowing, how come?
disconnect the starter and turn the ignition to see if the fuse blows, if it does not then the starter is grounded, but more then likely there is a stripped/bare wire grounding out somewhere. Hope this helped Tim
Jun 05, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mower deck belt pulley gone
There is what they call the spindle assembly. Some times if the bearing is not lubed enough or just plain old it will sieze up . When this happens the pulley shears off of the rod it spins on. The deck must be removed and you can buy a new spindle assembly. In most cases you need your old pully however or you will need a new one of those as well. The other possible solution could be the bolt came loos and it simply fell off . In that case you need a new pulley , bolt to hold it on , and a washer in the middle. Good Luck I just had this same problem on a mower I purchased to fix up. It cuts great now.
Aug 05, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My riding mower has a 42" deck with 2 blades. Left side cust much lower than right side. It looks like two different cuts. How can I fix this?
adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Jun 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed My mower is a 42 cut and leave a row in the middle of the cut
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Sep 30, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have to overlap about half my cutting deck to get clean cut.
A: Is the blade on right?
B: Is the belt on the pulley?
C: Is the blade tight on the spindle?
D: Does the spindle turn freely with the belt off?
I can't think of any other possibilities
Jul 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
2005 Poulan PD17542LT Lawn tractor, It starts fine but after cutting my front yard (20-30min) it dies, it will start up but dies in a few sec. If I let it set and cool off I can get 20=30 min till it gose...
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
Jun 22, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
91 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
