Question about Garden
I need to find the model and serial numbers of a Toro personal pace mower which i no longer have. Thanks.
#1 Taper
  • 1040 Answers
SOURCE: SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
Posted on May 30, 2009
  • 81 Answers
SOURCE: Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Posted on Jun 19, 2009
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Posted on Aug 02, 2009
SOURCE: Toro model 20038 self propel problem
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Posted on Sep 12, 2009
bulldogchief
  • 388 Answers
SOURCE: How do you change from bag to mulch?
Take the bag off. That is all you need to do. The blade is a mulching blade. When you take the bag off, there is a spring-loaded door that will close off the opening in the deck where the bag was. That is all you need to do my friend!
Posted on Oct 16, 2009
Toro model 20332. Have put new transmission, belt and new drive wheels on back. When I use the personal pace bar it makes a grinding noise. Doesnt make noise unless I push that down.
Sounds like either the gears on the wheels or ends of the trans shaft are bad, or the internals of the trans are bad. Are the parts actually new-new, or used and new to the machine, you didn't specify. What happens when you manually spin the pulley on the top of the trans in either direction?
Aug 14, 2016 | Toro 20332 22" Personal Pace Walk Lawn...
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Toro timemaster is 3+ years old and doesn't self propel when you push the handle forward any longer.
Either the transmission is shot or the gears on the wheels that turn have been worn away;. They are plastic and do not last long nor take much abuse.
Apr 04, 2016 | Toro TimeMaster 30" 190cc Personal Pace...
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
Lost instuction manual for Toro lawn mower 20333 (Walk at your own pace) . What kind of gas or oil do I use? How much of each or do I just use one of them?
I advise you to call your service provider about the lost of your manual. They can definitely help you get a copy of it. The manual for your Toro Lawn Mower is the best answer for your questions. Thanks.
Jul 10, 2011 | Toro Personal Pace CARB Walk Power Mower
How do you change the transmission in a 20067 toro personal pace lawn mower
I followed this video and it was pretty accurate. http://www.youtube.com/watch?v=eSaNVZaUi-k This is for a newer model mower but most steps are the same.
Jul 07, 2011 | Toro Personal Pace CARB Walk Power Mower
Toro 22" personal pace with key start. Just
Pull the air cleaner of to see if fuel is getting to carburetor. If it is then see if its getting fire to the plug by taking out and put the wire back on but be careful not to hold the wire or the plug if fire is week then get a new plug or get a new one and see it that helps
Jan 25, 2011 | Toro Lawn Mower With Toro Power Tools
Need the engine model number for toro mower model 2006,serial 270001124
I too was looking for the engine model number and serial number for my Toro mower to submit a claim for a class action suit. I could only find the "Mower" model and serial number. I found a guide to locate the engine information in the "Engine Service Manual" for my mower.To get the "Engine Service Manual", I went to Toro's website https://lookup3.toro.com/request/request.cfm and entered the "Mower" Model # and Serial Number. That brought me to a speific page for my mower with several manuals listed, including he "Engine Service Manual" which could be downloaded for free. The information for locating the Engine Model and Serial Number was found on the first page of the Preface. Here is a sample link for my mower Engine Manual https://lookup3.toro.com/request/filechek.cfm?Lang=EN&PubNum=492-4202&PubID=6924&Cust=anonymous_user&xCaller=Toro&PubType=9
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
273 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
