Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator spindle isn't revolving
The bottom part of the agitator is working; but the top spindle isn't circulating. What could be the problem? Thanks!
  • 5,911 Answers
If the problem is just the agitator auger not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers (such as Kenmore) use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. These parts are commonly sold as part of their in-store inventory.
Read through the information provided and let me know if you have any questions. I hope this is helpful to you.
Posted on May 30, 2010
    Novelist:
  • 160 Answers
Replace the dog agits. You can also get a agitator repair kit. It has a few extra components.
The spindle works on top and bottom with small load, but the top of spindle doesnt work with a large load of laundry.
Replace the agitator dogs in the top portion of the agitator.
This video will help.
http://www.youtube.com/user/RepairClinic#p/search/0/0GQh8JLqVv8
Aug 21, 2011 | Washing Machines
The center spindle seems to have raised upfrom the bottom more than normal and the top portion seems looser and rattles when operating.
Remove the cap off of the agitator and you will see a bolt down inside of it. Tighten this bolt down to secure the agitator.
Jan 05, 2011 | Washing Machines
How to disassemble the agitator after removing from the tub. The cam and dawgs need replaced. Agitator top and bottom appear pressed together.
After you remove the cap on top there will be a 7/16 nut. Remove that nut. The whole thing should slide up and off. If you put the agitator on the ground and stand on two sides of the base and give a quick ****, It will seperate. Slide the sleeve away from the dogs and replace them. The top snaps back together, slde back on spindle and replace the 7/16 bolt. Replace cap.
Sep 06, 2010 | Whirlpool LSQ9610L Top Load Washer
The agitar isn;t working right. Is there
The part you need is FSP# 80040 dog kit goes inside the upper agitator. installing them dawgs: You sit the agitator on the floor, put you feet on the base and snatch the top portion off of the bottom. You put all the dogs back in the cam set them up into the upper portion with a piece of pvc pipe or equivilent and invert onto the base, lining up the tabs on the bottom with the holes in the upper portion being careful not to smash the tabs on the base that hold the upper portion onto the agitator. Snap it all into place and gently re-install it being careful not to over tighten the nut. Watch this video:
Jun 06, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Top Wash Arm not Spinning
water is not circlating, you need a circulation pump
Feb 24, 2010 | Bosch 24 in. SHV55M03GB Built-In...
How to remove the spinle blades from washing machine
you did good with the brand . if it's older model there is a spline at the top agit . and if its a newer style the drive is at the bottom . ineither case it just pulls of . but they do stick . I use a agi-tamer ( brand name . it is a flat type heavy rubber round tube with a split in it slide it under agit add water and it will raise it up .. hopt this will help mm
Dec 12, 2009 | Refrigerators
I have the dog agits to replace Whirlpool top load washer LLR6233AWO I have the dog agits to replace in my top agitator and cant figure out how to take the top off the bottom
On mine I pulled on the fabric softener plastic top.And under it was a cap. I pulled the cap off and looked inside to see a bolt (I think it was a 1/2" size. I needed a 1/2" socked and a 6" long extension and took the bolt completly loose. Righty tighty ,Lefty loosey. Then I just pulled up on big center plastic part and the dogs are under it. I hope this helps you.
Sep 04, 2009 | Whirlpool Washing Machines
Mixing center spindle won't aggitate
Your agitator dogs are worn out.
Remove the agitator and replace the 4 little rubber dogs.
Snap the top off. Remove the bolt inside. Pull up on the top part and access the dogs.
Mar 26, 2009 | Whirlpool Washing Machines
Agitator won't work
you need to replace agitator dogs,they are located in agitator.pop top off and one bolt holds it to tub,remove bolt and remove agitator.pop top part off agitator and you will see little plastic agitator dogs.should be 4 of them.that is what grabs agitator to circulate your clothes.very cheap part to replace.
Mar 09, 2009 | Kenmore 20722
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
373 people viewed this question
Dan Webster
Dan Webster
Sal De
