Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Need routing guide for main drive belt
Just need to know where i can find a scematic to put the belt back on
lt2000 model #917.274751
  • 66 Answers
Hopefully this will help
Posted on May 31, 2010
Where do I find a diagram on how to put belt on mower
Larry, diagram on how to put belt on mower, Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.husqvarna.com/ddoc/husi/husi2011_naen/husi2011_naen_lgt2654_532446566.pdf
http://www.fixya.com/fullimage.html?src=http://i.fixya.net/uploads/images/deeb035.jpg
http://www.searspartsdirect.com/model-number/gth2654/3199/1509200.html
Aug 27, 2016 | Husqvarna LGT2654 54 inch 26 HP Kohler...
Tensioner belt keeps slipping off front pully
Everett, Do you mean drive belt keeps coming off front pulley?
Possible causes, accumulated dirt/debris above deck or on trans axle, damage,stretched,wrong size belt, belt tensioner seized/missing spring if equipped, belt retainers/guides/keepers damaged /missing/ adjusted to far from pulley, damaged/worn pulleys, loose engine, belt way out of alignment,etc.
Check the attached links,instruction and guides, Good luck
What Are the Causes of Belt Coming Off Riding Mower
Drive belt keeps coming off when shift into reverse
Need help with mower deck belt keeps coming off Craftsman LT2000...
belt keeps popping off
Jul 20, 2016 | Garden
Troubleshooting lt2000 craftsman riding mower
it could be but if it kept going with the clutch in i would guess the belt is the wrong one or it was put on incorrectly. not saying you don't know what you are doing but it happens a lot where the belt was routed wrong and did the same thing you are saying. be sure it is routed correctly.
Jun 20, 2016 | Craftsman Garden
How do i replace belt in a 08 ford fusion
Anon, Take a picture of belt routing before you start as you may forget how to route belt when putting new one on. Check the attached links,instruction and guides, Good luck
changing the serp belt 2 3L 2 5L
HOW TO REPLACE SERPENTINE BELT
How To Change Serpentine Drive Belt Ford Focus
Jun 01, 2016 | 2008 Ford Fusion
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
I need the diagram for the fan belt on a 1992 3.0 L ford ranger.
Go to autozone dot com and make a free account, then put in the make and model and year and use the free repair guides.
Nov 29, 2012 | Cars & Trucks
Husqvarn lgt2654 wont pull
Make sure the drive belt is routed right. Go to partstree.com click on
husqvarna and put in your model number and click on the drive scematic and it will show the routing of the belt.
Jun 23, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Need help I have a saab 93 convertable 2.0 i non turbo 1998 model drive belt has gone dont know where to find the ajuster to put the belt on. And a diagrame to see how it goes on.Regards James.
Here is a link to a Dayco PDF file that will have a belt diagram for you. Find you car on the main page, fine the number to the diagram and thats how you belt routes. Depends on month of manufacture yours could have 2 guide or tensioner pulleys. Facing the engine, one should be the top left pulley, that one is common to all. The optional tensioner will be the next pulley to the right. If one is missing it may have fallen off and you may be able to run a shorter belt.
Mar 02, 2011 | 2000 Saab 9-3 Viggen
I need to know the route of the drive belt around the pulley syst
go to www.searspartsdirect.com and you can look up the diagram on their website.
Also you can download a free owners manual at www.managemyhome.com.
Jul 21, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
287 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
