Question about Dell Inspiron 1501 Notebook
Code 2000-0111 I replaced the memory and installed new operating sys.I did diagnostic test and I had the code 2000-0111.The problem I had before is the same as now Hardware malfunction. What can I do??
  • 468 Answers
Best you can do is to contact Dell Support
Posted on May 30, 2010
My Ford Focus car doesn't centrally lock anymore, I have to use the key. It's not the fob battery because I changed it.
Sure you did put in a new battery? sure you did insert it correct? not the other way around? sure you did use the correct battery? like CR23 or AAA?
Sure all contacts in the battery compartment and on the battery are clean and shiny?
just a few things you could check.
Feb 09, 2015 | Ford Focus Cars & Trucks
Why won't my car start?
Run diagnostics on the "old car". You can still access possible trouble codes through the key switch, and have 2 digit trouble codes flash out from the check engine light. Here, for the procedure: http://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
Beyond that, it is basic diagnostics. Check fuel pressure, check for gas and spark at the cylinders. Test the fuel injection circuit.Test the ignition coil. Test sensors for proper operation. A mechanic with a multi-meter can do a ton of diagnostics. I don't get it, does your mechanic only work on new cars?.
May 02, 2014 | 1995 Chrysler LeBaron
1998 dodge intrepid loss of power and chk eng light came on
Hi:Just one code there, or your descripotion is about two or mode fault codes; we will need exactly what code number is detected there.
You could find code description here: obd_codes.html
Hope this helps
Mar 05, 2012 | 1998 Dodge Intrepid
Loss of power.chek engine came on. did diag. test and said:heated cat.wec air sys. and acfridge
Hi there:Just one code there, or your descripotion is about two or mode fault codes; we will need exactly what code number is detected there.
Hope this helps.
Blue screen on start up tech information stop:0x000000024
try safe mode, if you can get into safe mode try sys restore if still same hold the Fn key down while sys is off and then press the power button like turning the computer on to run diagnostics - if sys fails with an error code like 0142, 0143 or 0146 its hard drive failure. you have to replace the drive but if it passes the test you have to reinstall windows.
Nov 11, 2010 | Dell Latitude D600 Notebook
Blue screen error acer desk top
hi friend the blue screen comes when there is a 1:hardware problem
2:virus problem
3:Installation Disk is corrupted
4:RAM problem
First, check your CD and clean or replace it as necessary. Your next step should be to test your system memory for errors with a diagnostic program.
To do this obtain the Windows Memory Diagnostic or Memtest memory diagnostic programs on floppy or CD we mentioned earlier, and use it to boot your system and test the memory. If either of these programs shows any errors in your memory, you have likely found the source of your troubles.
Chances are you will need to purchase new memory. For more information on faulty memory and memory diagnostics, see PCstats Guide to diagnosing bad memory .
Mar 31, 2010 | Acer Aspire™ T180 PC Desktop
My friend owns a joybook R53U with windows xp installed her computer froze and she switched off manually instead of shutting it down properly. now it turns on gets to the safe mode options part then loops...
Hmmmm....
Looping restarts are a pain, mainly because you cannot see the error code associated with them. I am going to assume it is a generic driver error (error code 0x00000007E). That is a generic driver issue. If you cannot start in safe mode, then you likely have a bad memory chip or a hardware device going bad (probably the video chip). Get the diagnostics discs and run some tests on the hardware and memory. IF your hardware passes the diagnostics, then the OS could have a faulty driver. If thats the case, you may need to reinstall. But, before you go that far, try replacing the memory chips.
Nov 07, 2009 | Computers & Internet
I have a dell inspiron 1520, today when I was trying to play a video song it couldn't play in a flow there was some obstruction then I tried audio song and the same problem was happening with that also....
the problem is with your memory card as one memory module is not functioning which is in DIMM 1. you need to replace it.
because which playing music file as due to damage memory it takes time for buffering. and that is why you hear choppy sound. you can also run a test on memory. Restart the sys. and press F12 on blue Dell Logo. and goto BOOT TO UTILITY PARTITION and run a test on memory it will hardley take 5 mins. and it will give you the result.
Nov 04, 2009 | Dell Inspiron 6400 Notebook
Unable to boot into windows
what are the things that you added recently, hardware(additional hdd, memory, video card) or software (antivirus, office, etc games.) try running a hard drive diagnostics, usually computer manufacturer install a hdd diagnostics on their BIOS that you can run. hit me back on the results.
Apr 28, 2009 | Dell Inspiron mini 9 - Black , Intel® Atom...
Dell Inspiron 1501 Notebook Logo
366 people viewed this question
Alun Cox
