Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
I have a Westell 327w My companies laptop connects fine but my daughters laptop will not. Her computer can connect to other wireless just not ours. Any help greatly appreciated
    Genius:
  • 1,354 Answers
Hi
may your wirless is prodected by password
just folow the setp
click on wirless icon on screen try to connect it will ask you password
if you don't know the pass then
in explorer type your IP e.c. http://192.168.1.1
then it will ask router password just apply then you will able to see your wireless password from the router setting
Posted on May 30, 2010
How do I hook up my Westell wireless router to the zhone modem so I can use my laptop. I have to use a dedicated line with a zhone modem to get DSL service. I want to hook up my wireless router Westell...
Connect the Westell wireless to the Zhone as if the Westell is the PC that used to be connected to it. Then connect the PC (through any available port) only to the Westell. That's the WIRED connection. For the wireless to work, after connecting through the WIRED connection, there should be a CD that came with it that will help you configure the wireless.
Feb 18, 2010 | Zhone 6212-I3-200 Router
I HAVE A WESTELL VERSALINK MODEL 327W IWANT TO CONNECT TO MORE COMPUTERS TO IF DO I HAVE TO HAVE SOME TYPE OF ADAPTER IN ORDER FOR IT WORK
your westell is a modem/router which means you can hook up more computers wirelessly.
yes, if you're using a laptop make sure it has a wireless card and for desktop computer..you have to have a wireless adapter...
Feb 09, 2010 | Westell Wirespeed VersaLink...
No wireless connectivity with Westell 327w
on the back of the modem is a reset button. try resetting and bridging the modem again.
Apr 09, 2009 | Westell Wirespeed VersaLink...
Can connect only one computer at a time over westell 327W modem
Try this, go to network connections, right click on your connection, click on properties, where it says this connection uses the following items, scroll down to internet protocol, highlight it then click on properties below it, make sure Obtain IP address automatically is checked. do this on both computers. Let me know if it works. lone99star
Jan 15, 2009 | Westell Wirespeed VersaLink...
Wireless connection
Make sure the wifi capability of your laptop is turned on or enabled.
Dec 09, 2008 | Westell Wirespeed VersaLink...
Westell model 327w router
if this is the first time you're trying to connect your laptop with the gateway, if this is a windows operating system, you have to go to your wireless zero configuration so that windows can automatically configure the wireless connection of your laptop. you cann see that by clicking on start, and then run, and then type in the box services.msc, and then search for wireless zero configuration click on start if the service has not yet started. if this doesn't work check your built in wireless adapter, uninstall and reinstall it. try to access your westell by typing in 192.168.1.1 in the internet explorer address bar. the default username and password for that is admin and password. you can configure the wireless settings in the modem by going here. the WEP key for your wireless connection can be found below your westell modem/router. if i'm not mistaken this is the westell 327 versalink right? you can also find out if your laptop is connected to your modem by checking your computer's ip address. it should be 192.168.1.xx. if it's like this, your laptop is connected to your 327w. if it's a 169.xxxx ip address, you're not connected to the modem. the best way to configure your laptop and modem wirelessly is to configure it while you're connected using an ethernet cable.
Oct 21, 2008 | NetGear DG834G Router
SMC Barricade g SMCWBR14-N Wireless Router... router Configure with Westell 327W
it seems that the router capability of both devices are conflicting with each other so below are the steps that you can try to setup the two devices to work with each other.
i assume that you are using pppoe connection from at&t and you are using a connection manager. if so, with the current setup that you have right, you need to disable the connection manager on your computer (network connection, disable at&t connection) and set the connection of your web browser to "never dial a connection". check now if you will be able to connect to the internet instead of being prompted for a password. if your problem is still the same, try the steps below.
configure the westell 327w the way it was before (when it works properly when hard wired to the computers but the wireless sucks) but disable the wireless capability. change now the ip address of the smc router from it's default (192.168.2.1) to an ip address which is on the same segment as the ip address of the westell 327w (ex. 192.168.1.2 if your westell 327w is using the ip address 192.168.1.1). disable the dhcp of the smc router (note:make sure that you have configured all the settings that you want to configure with the smc (i.e. wireless settings, port forwarding, etc). then connect the westell to one of the LAN ports of the smc (note: with this setup, the wan port of the smc should not be used) and power cycle everything and check if this setup will work.
hope this'll help you and just ask me if you have other concern.
ciao!
Oct 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Aug 20, 2008 | Westell Wirespeed VersaLink...
Verizon Westell 327w modem cannot connect to internet
hi. i work for verizon tv, internet and phone. and the tech was wrong. it is the unit it self how old is it?
Aug 07, 2008 | Westell Wirespeed VersaLink...
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
135 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
