Question about LG Cell Phones
Screen is black with scratch-like marks appearing at the bottom of the screen
  • jackkuderian May 30, 2010
    thanks much - the phone was not dropped or anythingl ike that and the store is refusing to honour its warrantly so i will bring your reply back to them and try again
  • LG Master
  • 6,993 Answers
what's the model and make of your phone? Also, did your phone fall on the ground or did the screen hit on something?
If your phone is a flip or slide, then there is every possibility that it might be a flex problem. There is a flex connecting the screen to the phone's main board, if the screen worn out or get weak, or not well seated (it may have shifted from its normal position), can cause the screen to misbehave. Fixing the flex or replacing the flex can solve the problem in this case.
But if your phone is not a slide or flip phone, then you will have no option than to replace the screen.
I hope you understand my explanations.
Take care.
Posted on May 30, 2010
We have got a black scratch in the bottom of our white plastic bath can this be fixed
How deep is the black scratch? Is it a scratch of just a black mark that doesn't want to come up.
If you have not tried it yet, get some Denatured Alcohol and use it to clean the black mark. That is a really good cleaner that will not harm the surface of your tub.
US Parts Center
Sep 04, 2013 | Home
Broken top screen on 3ds
You need to buy a new one and think twice before throwing your next Nintendo. Thank you.
Feb 07, 2018 | Video Game Consoles & Games
Black marks on screen
my lamp problems usually start with red shades in bottom corners - red, black - same issue I think.
check your hours of filter (and clean) - clean inside your housing as helps and check lamp hours - you usually get 1500 to 3000 hours (check your user guide for lamp hours)
try and live with problem until you need new bulb as not cheap
good luck
Jan 27, 2013 | NOBO X28 original lamp
There is a large scratch on the screen, and appears black when the monitor is on. My monitor fell and hit the edge of a shelf because I had it leaning forward too much. Obviously, the mark is deep, and the...
It is evident that the LCD panel of the monitor is damaged. If your computer has Dell complete care you can get the monitor replaced. If not you can contact a local technician and get the LCP panel changed, with the remaining circuit boards and backlight assembly intact.
Jan 27, 2011 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Scratch in sreen
By the looks of that picture, it's hard for me to believe that the scratch is not on the outside of the protective plexiglass screen. However, you can remove the protective screen w/o negative effect of the picture. In fact, it will probably reduce the glare from light on the screen. If, in fact, the scratch is still seen w/o the protective screen installed, then it is the lenticular screen that is scratched.
The lenticular screen is the one with the vertical grooves from top to bottom in it. The fresnal is the back screen that appears to have been lathed in a circular pattern.
Jan 07, 2009 | Toshiba 61HX70 61" Rear Projection...
Repaire scratches on a lcd flat screen
The eraser method is even better than I first thought.
I acquired my first scratch some weeks back, tried the eraser method, and was quite pleased with the results, as my scratch was approx. 80% less visible, a faint grey line visible only on very light or dark coloured backgrounds, instead of the glaring black line it was at first.
Today my monitor toppled again (I really must tether the damn thing to something next time) creating - gulp - a new and even larger scratch. Oh, no... But whodathunk I'd end up happy I got the 2nd scratch? Oddly, I am happy, 'cause I took the opportunity to lay the monitor flat, take my white eraser again , and really go to town rubbing both new & old scratches. Lo & behold, both scratches appear to be now virtually 100% invisible or gone. My 2-scratch monitor is better now than it was as a one scratch one! I'm now convinced it's partly, largely, or completely due to the heat from friction of rubbing the eraser across the scratch, plus pressure applied, that does the trick. The heat must soften the plastic surface making it malleable, and the pressure of rubbing smooths out the jagged scratch edges, making the scratches disappear.
-So, if at first your eraser doesn't completely eliminate your scratch, try, try again! Keep working on it - harder!faster! And with luck, you'll get results like mine: complete elimination of two ugly scratches!
Apr 25, 2008 | Computers & Internet
Lines on top and bottom on projection TV
What sort of lines? - do you mean like it is in widescreen mode with a black band top and bottom? Do you mean you have clear straight lines, or streaks or scratch-like marks? Is it the same for all input sources (cable, DVD/VCR, satellite, PC, camcorder etc.? Could you post back a photo of the lines? Waiting your info:)
Jul 16, 2007 | Sony KP-43HT20 43" Rear Projection...
Cell Phones Logo
15 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
