Monitors
Problem for Monitors
Generic problem for all Monitors
Desktop larger than screen
By Feverything on Apr 08, 2008
Details:
I'm using ATI Radeon RV250 9000 series graphic card (AGP) and EIZO FlexScan T563-T CRT monitor on XPSP2 Professional. They are connected via common VGA cable. I have latest as well as some older drivers for both devices but I'm having trouble getting them to work together. My desktop is much larger than screen although I'm using DDC information from monitor. It looks like desktop is magnified a lot. When I override DDC and manually enter display resolution, desktop reduces to fit the screen but than everything gets blurry, with multiple shadow and some strange vertical artifacts. The higher refresh rate I set the worse it gets. There is no forced hardware, no conflict hardware, everything seams to be fine butI 'm obviously having some incompatibility problem with my monitor and graphic card. I've read on several places on the web that other people are also experiencing compatibility problems between Eizo monitors and ATI graphic cards. Both monitor and graphic card have been tested on another computer and they work fine (when not used together). I'm not a beginner but someone who maintains and repairs PC's for more than 20 years so it is definitely not something regarding basic or advanced settings I've overlooked. I've also contacted EIZO technical support and they confirmed that my driver is ok. Same thing with ATI support who suggested that there might be incompatibility issue and suggested replacing hardware.
So, what can it be? Is there some way to solve this problem?
Thank you in advance!
Comments:
Apr 08, 2008
- Graphic card works fine. I've tried it with another monitor and there are no problems at all. This EIZO monitor also works fine on NVIDIA graphic card but not on ATI graphic card. So, system works fine. I've found on the web identical problems experienced by other people. EIZO+ATI≠♥
Apr 09, 2008
- Apparently the problem is between Eizo driver and XPSP2. One guy who has same problem on identical configuration said that it happened to him (identical problem) when he upgraded his XPSP1 to XPSP2.
Clarification Request
Posted by Nitrotrike on Apr 08, 2008
Silly question, but have you installed the AGP slot drivers for the mainboard?
It may be defaulting to standard chipset drivers, and it doesn't "know" that it's an AGP.
Solution #1
posted on Apr 08, 2008
Somewhat Helpful)
myob247
Rank: Guru
Rating: 86%, 1027 votes
Is AGP enabled in the BIOS?
Comments:
Apr 09, 2008
- Glad to hear you figured it out. Hopefully Eizo or Microsoft will come up with a fix.
Thank you for voting.
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
Text is hard to read for lack of contrast Colors look washed out Cannot get improvement using the... (More)
Answer
xerox 900p comes on then shuts down ive changed all the psu caps
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitors Experts
Top Computer & Laptop Repairmen
in , AR
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
