Question about Nintendo Wii Console
Nintendo wii console
My nintendo wii will turn on but makes a loud ticking noise as its trying to load. but it wont load any of my games.
That happened when I recieved my Wii... I found out that my Wii was damaged and I had to get a new one.
Posted on Apr 09, 2008
Try setting the console horizontal. That solved my disc read errors.
Posted on Apr 08, 2008
My Wii console makes a loud noise and the screen freezes when I try to access the "music store" for both Rockband2 and Beatles Rockband. It starts to load, then freezes and makes a loud...
try these:Solution 1-go to the wii shop channel
Solution 2-Delete internet configuration and set up internet on the wii
Solution 3-Unplug Wii and internet for 5 minutes, reconnect and try again
Solution 4-Check the disks for scratches and smudges
Solution 5-Clean the wii Disk Drive
Jan 25, 2011 | Nintendo Wii Console
Wont read the disc. says to turn off and see manual. i did. i unpluged the back for 5 min like it said and it still wont work. also makes a loud noise when disc is inserted.
This is caused by a dirty laser or bad laser. try cleaning it with a q-tip and alcohol. If that doesn't work contact Nintendo and see if it is under warranty.
Feb 10, 2010 | Nintendo Wii Console
My wii takes dicks but makes a noise when spins
There is always a sound like ''a disk is turning'' and there is always a ''beep'' when a disk is turned in, does there come light on the side? If, do the following things: if not, contact Nintendo always.
I recommended buying a lens cleaner, or contact Nintendo.
Dec 04, 2009 | Nintendo Wii Console
Loaded game = loud buzzing
After removing the casing, all that need to be done was loosen (yes, loosen) a screw on the inner frame about a quarter turn. This allowed a little movement to the frame and stopped the buzzing.
Jul 22, 2009 | Nintendo Wii Console
High pitched squealing and now not working
Seems like the wii froze. Try other discs and if worse comes to worse send the wii to nintendo
Dec 31, 2008 | Nintendo Wii Console
Wii making strange noises and wont start game
Unplug anything you have connected via USB. Try that as it has been a constant issue for many first gen Wii's
Oct 31, 2008 | Nintendo Wii Console
Noisy wii console
Hi Sky606, have you tried cleaning the game disk? Have you tried using other game disks in the wii to make sure it's not just one disk that is causing the problem. Do you have a Nintendo Wii CD / DVD Discs and Lens Auto Cleaning System ? If you don't you might want to purchase one and see if that helps, because your wii lens might need cleaning ! If all of that fails,your wii may need repairs, the lens that reads the CD/DVD could need adjustment or replacement ! One other small note,I always have a small external fan blowing on my wii when in use so that the wii wont over heat. Heat kills electronics ! I Hope this advice helps.
Jun 06, 2008 | Nintendo Wii Console
Wii
some loose connection inside or change your sound settings
Oct 21, 2007 | Nintendo Wii Console
Wii wont take in CD!
sounds like slot disc loading mechanism gearing is misaligned.. Slot drives are difficult to fiddle with, I suggest you try to get this repaired under warranty, (don't mention that you dropped it though, just say it stopped working)
Sep 15, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
190 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
